Other connecting case tomotherboard help
Discussion in 'Hardware' started by s1n1s, 2 Nov 2009.
  1. s1n1s
    s1n1s What's a Dremel?
    5 Aug 2009
    I need help connecting my case to the motherboard
    CASE CABLES(USB)
    VCC, USB1-, USB1+, GND, seperate GND
    VCC, USB2-, USB2+, GND, seperate GND
    MOTHERBOARD SLOTS(USB)
    USB56
    USB+5V, USB_P6-, USB_P6+, GND, NC
    USB+5V, USB_P5-, USB_P5+, GND
    USB78
    USB+5V, USB_P8-, USB_P8+, GND, NC
    USB+5V, USB_P7-, USB_P7+, GND
    CASE CABLES (AUDIO)
    MIC GRD, MIC IN, MIC POWER
    HPOUT-L, HPOUT L, GROUND, HPOUT-R, HPOUT R
    MOTHERBOARD SLOT(AUDIO)
    AAFP
    GND, PRESENCE#, SENSE1_RETUR, empty slot, SENSE2_RETUR
    PORT1 L, PORT1 R, PORT2 R, SENSE_SEND, PORT2 L
    Legacy AC'97
    AGND, NC, NC, empty slot, NC
    MIC2, MICPWR, Line out_R, NC, Line out_L
    any help would be great thanks
  2. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Read the manual.
  3. trig
    trig god's little mistake
    10 Aug 2006
    lol...Cheesecake
  4. s1n1s
    5 Aug 2009
    I have thats why I come here :)
  5. trig
    10 Aug 2006
    the typical headers, power, reset, hdd activity...thats all pretty standard and should be pretty much explained in the manual, same for any usb connections. the manual should show you where to plug in usb, firewire...etc. so what exactly are you not getting?
  6. s1n1s
    5 Aug 2009
    the codes on the cases cables don't match the motherboard codes, when I read through the manual it said do not plug the 1394 cables into the usb slots as this will cause damage really i just want to know that my cables from my are not these
    tbh it's not my pc which is the reason I want to be totally sure about this I would assume they are not however since it' not my pc I do not wish to be blamed
  7. trig
    10 Aug 2006
    1397 is firewire...
