Displays Connecting Secondary Monitor.
Discussion in 'Hardware' started by Kronos, 21 Feb 2015.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
    I have my primary monitor connected via DVI and have two HDMI and two Playport connections remaining/ Which should I connect my secondary monitor to?
  2. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Without knowing what versions/types of HDMI (version number), DVI (single-link, dual-link), Displayport (version) you are connecting i would go for Displayport.
  3. Kronos
    Kronos Multimodder
    6 Nov 2009
  4. fuus
    fuus Rocking All Year Christmas
    4 Dec 2010
    don't think it matters too much Kronos
  5. Kronos
    Kronos Multimodder
    6 Nov 2009
    Okay thanks. I will go have a root around the magic cable box and see what I have.
  6. Corky42
    30 Oct 2012
    It's more what it's connecting too, but fuus is probably correct when he/she says it won't mater much.
    It's just things like HDMI 1.4 maxes out at 3,820x2,160 30fps, or a DVI single-link is limited to 1,920x1,200, etc, etc.
  7. GMC
    GMC Minimodder
    26 Jun 2010
    Your dvi is dual link so you can connect pretty much anything to it if you have a dual link cable, dont connect more than a 1080p (16:9) monitor to HDMI, high res to display port. General rules should be all you need
  8. Kronos
    Kronos Multimodder
    6 Nov 2009
    I have connected the 24" secondary via HDMI and all is fine.
  9. Kronos
    Kronos Multimodder
    6 Nov 2009
    OK so why does it now show the secondary monitor (HDMI) as number 1 and the primary monitor (DVI) as number 2?
  10. fuus
    4 Dec 2010
    From what I gather those numbers mean very little as long as your primary display is set correctly in the Nvidia control panel. Look on the 'setup multiple displays' tab
  11. Kronos
    Kronos Multimodder
    6 Nov 2009
    Will do thanks.
