Conneting a console to a video input
Discussion in 'Tech Support' started by cyrilthefish, 8 Nov 2007.
  1. cyrilthefish
    cyrilthefish What's a Dremel?
    15 Apr 2004
    Have to admit i'm being tempted by the dark side (console gaming ;) )
    Theres quite a few xbox360 games i want to try, most will be borrowed from my friend... However, the main problem i have is i sold the TV in my room ~4 years ago through total lack of use :p
    I do not want to buy another TV as i do not have the room for it, what would be perfect though, is to use my PC's screen for it (doubly so as i'm planning to get a 22" or 24" LCD after xmas)
    Now, hardware-wise i have a Radeon HD 2900XT with full AVIVO (video in/out) which i presume could handle it, but i'm a bit lost how you'd actually use it...
    Doesn't seem to be any software provided to play input video, unless i'm missing something obvious :)
    I have my old gamecube to use to test the video input before i go buy anything as well.
    Any ideas as to where to start?
  2. Krikkit
    21 Jan 2003
    What monitor do you have atm? Does it have multiple inputs? The easiest way to connect something up that I know of would be to get a DVI convertor (assuming you have a spare DVI port) and plug it in directly.
  3. Bluephoenix
    Bluephoenix Spoon? What spoon?
    3 Dec 2006
    does the tuner accept component input?
    if not you may have to get an HD tuner with component or wait and get a 24" screen with component input
  4. mrlanrat
    mrlanrat What's a Dremel?
    11 May 2007
    I use a cheap TY-Tuner that has S-Video and Composite in.
  5. Bluephoenix
    3 Dec 2006
    so do I, as I only have SD consoles, and by using GB-PVR in RAW mode I can get real-time feed but still record game footage.
  6. crazybob
    crazybob Voice of Reason
    21 Oct 2004
    I think the best thing to do would be to buy the fantastic Dell 2407WFP, which aside from being an excellent monitor, has VGA, DVI, Composite, Component, and SVideo outputs. And I'm sure there are cheaper monitors with similar offerings, but the Dell is the only one I have personal experience with.
    I can't offer you any help for using your current hardware, though. I've never used a tuner card.
  7. Delphium
    Delphium Eyefinity enabled
    18 Mar 2007
    So long as the Video capture drivers are installed, you could use the likes of VLC which can capture from video input cards (File > open capture device) . :thumb:
  8. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    If you're using a Xbox360 then you can just buy the VGA cable for it, and connect it to your existing monitor directly. Its by far the easiest way.
  9. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    Is there not lag using the tuner card. Last time i tried, Sonic was unplayable given the delay from the console to the monitor via the P3 pc.
    edit:
    Also watch your aspect ratio, last time i looked at buying a 360 it didn't support 16:10 for my widescreen.
  10. Bluephoenix
    3 Dec 2006
    you remove the lag by turning off live preview, this gives the raw uncoded feed
    GB-PVR is the only program I've found so far with this capability
  11. cyrilthefish
    15 Apr 2004
    Firstly, thank you for all the replies :)
    This 17" LCD at the moment BenQ FP737s-D
    and also a 17" CRT as a secondary screen
    DVI port on the LCD is in use, but the VGA port is free.
    (also, if i do get a new screen, this LCD will replace the CRT as the secondary screen)
    I never knew that, that helps a lot, i shall try it this weekend :)
    This sounds the best solution if i don't get the 2900XT video-in working properly :lol:
