Linux Conroe 64bit linux?
Discussion in 'Software' started by veryevil, 8 Sep 2006.
  1. veryevil
    veryevil Minimodder
    14 Aug 2005
    Hey, just gone to install debian on my new box and i just realised im not sure what architecture to get to try a 64bit operating system? Is it still i386 or somthing else?
  2. Glider
    Glider /dev/null
    2 Aug 2005
    There should be a 64bit counterpart, probably named x86_64, but i368 (or 686) [x86] will give you 32bits, which is compatible.
  3. veryevil
    veryevil Minimodder
    14 Aug 2005
    Hey these are the options given [alpha] [amd64] [arm] [hppa] [i386] [ia64] [m68k] [mips] [mipsel] [powerpc] [sparc]
  4. Glider
    Glider /dev/null
    2 Aug 2005
    ia64 is what you want I guess, not 100% sure, give me a minute, I'll check ;)
    EDIT: Yep, that's it
  5. trigger
    trigger Procrastinator
    22 Mar 2004
    Are you sure Glider? Only the article says IA-64 is for Itanium - a whole different kettle of fish. I would have thought that i386 would be the one - I didn't think Conroe was 64bit? Perhaps ask on the Debian IRC channel - they should know for sure!
  6. eek
    eek CAMRA ***.
    23 Jan 2002
    I'd say amd64... Intel did copy AMD :)
    *edit*
    "AMD64 has been adopted (under the name EM64T or IA-32e) by Intel" - from wikipedia
  7. Elv13
    Elv13 What's a Dremel?
    26 Apr 2006
    it is EMT64, but only few distro have this version, amd64 is supose to work
  8. Philipp
    Philipp What's a Dremel?
    27 Dec 2004
    For x64 use amd64 (this includes all the processors made by Intel, too), ia64 is for Itanium/ItaniumII which are only used in some server-machines provided by HP, SGI,...
    HTH
  9. sinizterguy
    sinizterguy Dark & Sinizter
    25 Jul 2002
    Yep, AMD64 will work perfectly on the Intel chips in spite of the name.
