Conroe: Best mobo?
Discussion in 'Hardware' started by veryevil, 20 Jul 2006.
  1. veryevil
    veryevil Minimodder
    14 Aug 2005
    Fair Enough, so is CrossFire (2 X8 PCIe) fast or should it be 16x?
  2. Tim S
    Tim S OG
    8 Nov 2001
    you shouldn't see much of a difference between 2x x8 and 2x x16 with X1900 CrossFire
  3. chapellane69
    chapellane69 What's a Dremel?
    30 Jul 2006
    Isn't it likely that RD600 will also support mastercard-less Xfire, whereas the 975X requires the dongle? [I'm not sure I've read this anywhere, I think I'm just jumping to conclusions based on support in RD580 based boards for AMD processors].
  4. Tim S
    Tim S OG
    8 Nov 2001
    You can run dongle-less CrossFire on 975X, as far as I know... there will just be a large bottleneck. Performance will be better on RD600 though, thanks to the dual 16-lane interconnects
  5. Guest-16
    Guest-16 Guest
    Dongleless on certain cards, and next gen R600 Crossfire high end will be dongleless.
    High end atm passes far too much data across the PCIe bus to make it work: this is what Tim refers to as the large bottleneck.
  6. veryevil
    veryevil Minimodder
    14 Aug 2005
    Hey, wondering when these R600 boards are gonna start showing up as projects on hold till i can actually get hold of a conroe!
  7. scq
    scq What's a Dremel?
    4 Mar 2005
    Here's a noob question for you all...
    What are some guidelines I can follow to even make sure a board will run Conroe/Allendale?
    It's not simple like AM2 will run all AMD AM2 CPUS. So far, I just know there's P/Q965 and i975X, and possibly some 945 etc, and you have to check this revision and that.
    AHHHHH!
  8. chapellane69
    30 Jul 2006
    I've certainly read that people have tried mc-less Xfire with 1900GT's on 975XBX and it has not worked for them. I don't know about "lesser" graphics cards; Bindibadgi appears to suggest that it works (at least for some). I've only researched the 1900GT question, so I couldn't say.
  9. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    If they don't come out with some good conroe boards yet. I am going AM2. I am looking at a COnroe 6700 so if you guys find boards look up sli for me 2.
