Electronics Constant DC from varying DC (in a small package)
Discussion in 'Modding' started by Krikkit, 30 Dec 2008.
  1. Krikkit
    21 Jan 2003
    Hi guys, I've got a bit of a tricky problem here. (To my thin knowledge of electronics anyway!)
    I want to replace the bulb found in some scalextric cars with a single LED. (The bulb light goes through some perspex tubes to come out of the headlights etc)
    Can someone help me make something to provide a fairly constant DC voltage from the varying DC voltage that you get from the track?
    I measured the various outputs, and it varies from about 8V-16V fairly quickly, depending on the throttle position at the controller.
    Ideally I'd like something fairly simple that I can solder onto a single LED leg/small board to stick inside the car?
    There are some 3rd party circuits out there, but they're full-board type jobs which need fixing into the car, which I'd rather not do. Especially because they're ~£10 each.
    Upshot: I want a white LED to provide a near-constant brightness. :)
    Thanks in advance! :D
  2. capnPedro
    11 Apr 2007
  3. cpemma
    cpemma Ecky thump
    27 Nov 2001
    That's the way to do it, not.
    What you want is a Constant Current Source, which is easy-peasy with a 317 and a resistor.
    For 20mA LED current the resistor value is 1.25/0.02 = 62 ohms
    Circuit is
    Code:
    8-16V ----------- 317 --RES----+--------+
                       |           |        V LED
     0V ------------------------------------+
    Look out for the LM317LZ 100mA rating in a wee TO-92 package. Rapid have it, as do Maplin at only double the price.
    mvagusta likes this.
  4. capnPedro
    11 Apr 2007
    Damn you and your university degree!
  5. cpemma
    cpemma Ecky thump
    27 Nov 2001
    It's in Metallurgy... :lol:
  6. Krikkit
    21 Jan 2003
    Nice, thanks cpemma - I'm assuming, from the data sheet, that pin#1 on the LM317LZ isn't connected in that circuit. :)
    Should make for a tiny circuit, hurrah! :D
  7. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    I was thinking it could be done with a zener diode and a resistor? since it only has to drive one led and this would mean a very small size & weight.
    The to-92 package is very small and would have like a 50x better result, so definitely go with Cpemma's suggestion - as if that needed saying :D
    As for how to hook it up, check out the bottom of page 8 on the lm317 datasheet, where it shows how all three pins are used. You could use a smaller resistor like 39 ohm or 30 ohm to run the led at say 32 or 42ma, which can make some white leds really shine.. i dunno what type you have however? It wouldn't make a difference to how much power the motor receives btw.
  8. Krikkit
    21 Jan 2003
    Course it does! Duh!
    Well, that's certainly a great piece of work there guys, even at Maplin's extortionate prices it only comes to £2.31 per car with a fancy 3mm white LED.
  9. Alekoy
    Alekoy Ostekake!
    28 Dec 2003
    maybe add a 100uF capacitor before the resistor for the leds? so that the lights stay on a little while without the car moving, and in turns (does anyone actually release the trottle in turns?)
