Continuous restarting
Discussion in 'Tech Support' started by jarryd98, 3 Jul 2006.
  1. jarryd98
    jarryd98 What's a Dremel?
    3 Jul 2006
    Im having problems with my computer restarting randomly. It only does it sometimes. It could while im in a game or just browsing around. But I have brought it down to one cause. My onboard LAN Nforce 4. I can make it restart by enabling the connection. Soon as it finds the IP it will shutdown and restart. The only way it wont restart is through safe mode. And even with the onboard lan disabled it will still restart so therefore whenever there is networking activity it restarts.
    My specs are:
    Athlon 3200+ 64
    1gb of OEM ram
    xfx 6800 xt
    asus A8N SLI deluxe
    Windows XP SP2
    Any help is appreciated
  2. TheoGeo
    TheoGeo What are these goddamn animals?!
    10 Jun 2003
    right click my computer>properties>advanced>startup and recovery>settings>uncheck automaticaly restart
    next time it happens tell us what it says
    and welcome to the forums
  3. jarryd98
    3 Jul 2006
    info @restart
    this is what it came up with after a restart from the networkin thing:
    Page_fault_in_nonpaged_area
    tech info:
    stop 0x00000050 (0xAFA800ED), 0x00000001, 0xBA0728d4, 0x00000000
    HTTP.sys-ADDRESS BA072804 base at BA061000
    date stamp 41672042
    that is what the blue screen said upon restart.
  4. DougEdey
    5 Jul 2005
    Have you got the latest drivers installed?
    If so uninstall the nVidia IDE driver.
  5. hitman012
    hitman012 Minimodder
    6 May 2005
    Remove the NVIDIA firewall.
    (deja vu?) :confused:
  6. DougEdey
    5 Jul 2005
    Ever noticed how whenever someone is on nVidia chipsets we reccomend they disable or remove half the "extra special" stuff for it?
    Maybe someone should make a sticky for "Standard things to check"
  7. TheoGeo
    10 Jun 2003
    ahh, of course nVidia firewall. Didnt think of that since i never installed it in the first place after hearing so many bad things.
    There probably should be a standard things to check thread
  8. hitman012
    6 May 2005
    Good idea - bolted that onto here; PM me if you want to add anything.
  9. will.
    will. A motorbike of jealousy!
    2 Mar 2005
    not wanting to start another thread which would be very similar; My problem:
    My pc restarts randomly under load. Gaming mostly, but also sometimes when i'm watching dvd's and using photoshop.
    I'm not using nvidia, but for some reason there is nvidia software installed on my pc.. something to do with the mobo i would expect? However it wont uninstall, anyone, know how to force stuff to uninstall? Like a cleaner?
  10. hitman012
    6 May 2005
    Disable automatic restart first. Right click My Computer->Properties, then go to the Advanced tab and, under Startup and Recovery, click Settings. Uncheck the box labelled "Automatically restart" and then try to replicate your crashing problem.
    You should get a BSOD, the details of which would be helpful in diagnosing the problem. It sounds to me like you've got a problem with your RAM or its configuration more than anything, although it could be a PSU issue.
  11. will.
    2 Mar 2005
    I'm pretty sure its the ram, but i was told it could be the ram, but not because the ram is bad.. just a conflict with somethin else.
  12. DougEdey
    5 Jul 2005
    Have you tried disabling automatic restarts?
  13. TheoGeo
    10 Jun 2003
    also we could do with knowing your hardware as there might be known conflicts etc
