Other Conversion Software
Discussion in 'Software' started by User-sam, 30 Jul 2011.
  1. User-sam
    User-sam When in doubt, follow your nose.
    10 Apr 2010
    Hey Bit Tech Community
    I have some MP4 video files on my computer witch I want to convert into another video format so I can play them on my TV set-up is there any programs that allow me to convert them without having to do the really long process of recoding in other words direct video conversion I guess it would be called.
    Many Thanks
    Sam
  2. Odinster
    Odinster What's a Dremel?
    3 Feb 2011
    Don't kill me if I'm wrong as I don't know much about this, but I would presume it would be helpful if you knew what format you were converting into?
  3. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    Just to say I have tried about 5 free conversion softwares and all of them leave a watermark in the corner. Would I be right in saying that all free ones will do this?
  4. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
  5. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    I use Any Video Converter, seems to work for just about any format and lets you control the bit rate, codec & resolution etc- no watermark.
  6. User-sam
    10 Apr 2010
    DVD Video soft! Thank you so much for reminding me of this software, I used it a few months back and to say it was one of the best pieces of software I used Is an understatement, and sorry I was a little brief MKV or AVI was the format I was converting in to.
  7. Anne
    Anne What's a Dremel?
    31 Jul 2011
    What about SUPER? I heard from friiend about this free video converter software, you may check it out:lol:
  8. VeNoM JaCKaL
    VeNoM JaCKaL L4D2 nom nom time!
    16 Jul 2007
    Use Any Video Converter at work and have to say it is awesome. Free unless you are looking for specific formats such as iPhone or PSP compatible. Lovely queuing system, can set resolution as well as other parameters massive array of output formats.
  9. Guinevere
    Guinevere Mega Mom
    8 May 2010
    The correct answer is Handbreak
  10. lp rob1
    lp rob1 Modder
    14 Jun 2010
    Woo! Handbrake!
  11. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    ^This. Handbrake is hands down the best video conversion software out there. Plus its free :)
  12. Booga
    Booga Cuppa tea anyone?
    28 Sep 2009
    Super.
    I used it to make avatars, but it seems to be a comprehensive piece of kit and it is free.
  13. Bitemebad91
    Bitemebad91 What's a Dremel?
    6 Jul 2011
    Format factory
    -all in one
    -many extra features
    -free
    -easy
  14. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    Last week i used convert X to dvd for my dads friend, seemed to do the job OK, took about 40minutes to convert 6 hours of footage.
  15. Ken Peterson
    Ken Peterson What's a Dremel?
    31 May 2011
    Download MP4 to DVD Mac/Windows burner to convert any MP4 to DVD
