Windows convert .docx to .doc
Discussion in 'Software' started by Potus, 31 Jan 2007.
  1. Potus
    Potus What's a Dremel?
    26 Dec 2005
    Hi,
    I have a Word 2007 document, but I'm in school and need to print the doc. But the problem is that don't have office 2007. :miffed:
    So I need someone who has Word 2007, that would help me!
    I send the document, and the person saves it as a word 2003 compatible doc.
    -Potus
  2. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    heheh. can't help ya, but to avoid this kinda thing, always convert to pdf when you plan to print elsewhere. it's the most reliable format.
  3. Stickeh
    Stickeh Help me , Help you.
    20 Jul 2003
    email it to me before 10;30 and ill do my best to have it back to you as a .doc
    lankyjames(at)gmail(dot)com
  4. ArtificialHero
    ArtificialHero We were just punking him sir!
    25 May 2004
    If your school will allow it, you can install the Office Compatibility Pack which will allow earlier versions of Microsoft Office to read the .docx format. There is also a bit of standalone software here but the site seems to be down at the moment. Hope this helps. I can convert it for you if the other people fall through.
    AH
  5. Tibby
    Tibby Back Once Again
    9 Oct 2005
    There is a standalone converter somewhere on the microsoft site, my friend got e-mailed a link to it after registering the new windows office.
  6. fev
    fev Industry Fallout
    13 Aug 2003
    or... go to the office live site, open the document then re-save it
  7. imkeller
    imkeller What's a Dremel?
    8 Aug 2006
    Convince your school to update to Office 07 extremely quickly. Problem solved. :D
  8. dagoyvind
    dagoyvind What's a Dremel?
    9 Feb 2007
    convert docx to doc online
    Or you can try docx2doc. It's a fast and simple website designed specifically for these situations. You have a document created in Word 2007 and need a quick conversion to the old format....check it out
