PSU Converting a 24 pin mobo supply to a 6 pin supply
Discussion in 'Hardware' started by Goatee, 11 Sep 2020.
  1. Goatee
    Goatee Well-Known Member
    19 Apr 2015
    Quick question,
    I have a mobo that take its power (12V) from a 6 pin connection rather than the normal 24 pin.
    Am I right in thinking I could make a adapter to take the 12V from a 24 pin?
  2. Vault-Tec
    30 Aug 2015
    Yup. It should all just go back to rails.
    Ed. Or *a* rail (so single).
    Goatee likes this.
  3. RedFlames
    23 Apr 2009
    power wise, yes... as long as the 12v and ground wires from the 24-pin go to the right pins on the board.
    What might cause headaches is... how does the board send the power on/off signal to the psu?
    Goatee likes this.
  4. Goatee
    19 Apr 2015
    Dunno, magic? I might have to jump the PSU when powering pumps for water cooling.
  5. Goatee
    19 Apr 2015
    Thinking about it a bit more, I could run the adaptor from the 8 pin mono EPS, as the 24 pin cable only has 2 12v pins.
    then use a water cooling jumper to turn the PSU on....
  6. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Probably worth checking the rail those are tied into can handle it if its a non standard config
  7. Goatee
    19 Apr 2015
    True, I think it’s single rail, so should be fine.
    I now have a go forward path.
  8. faugusztin
    11 Aug 2008
  9. Goatee
    19 Apr 2015
