TVs Converting to a VGA signal
Discussion in 'Hardware' started by supaste, 3 Oct 2010.
  1. supaste
    supaste What's a Dremel?
    20 Jun 2008
    Is it possible to run a Componant or HDMI input into a VGA monitor? Bascially I'm looking to plug my xbox into this monitor which I rather stupidly bought which does not have HDMI slots nor is it HD enabled. I'm trying to find a converter cable to buy to do the job but I read somewhere that it's very difficult to convert a digital signal to an analog one without quite pricey equipment. Would something like this work - http://www.google.co.uk/products/catalog?hl=en&client=firefox-a&q=vga+to+component+female&cid=7093622705331766874&ei=Cr2nTOX_C6D6ygWevOmVBA&sa=title&ved=0CA8Q8wIwAjgA#p
  2. pimonserry
    pimonserry sounds like a party.
    20 Dec 2008
  3. supaste
    20 Jun 2008
    Yeah that's the sort of this I was looking at before. The point I was getting at is does it work and if it does - does it work well. Just I was reading somewhere that It's a bit of scam and doesn't work properly.
  4. Krikkit
    21 Jan 2003
    I didn't think HDMI-> VGA would work because HDMI is a purely digital connection? You'd need some electronic method of converting the signals.
    Component is a different matter, it's an analogue system so it shouldn't be a problem to convert to VGA. :)
    In fact a quick google gives you something to start with.
  5. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    You know there's an official VGA cable and plenty of knockoffs out especially for the xbawks?
  6. supaste
    20 Jun 2008
    OK so a vga cable for the xbox and a switch box sounds like it would do the job well however I've had a look at a few converters on Amazon just now - reviews report of serious ghosting issues.
  7. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    not sure it would pick up as a detected monitor by the xbox.. it could I'm not saying it won't just not sure- it might come up with something like analog monitor hopefully if they wrote that into the driver
    like if you convert dvi to vga and then convert to vga to svga, I know this from experience.. it doesn't always work.. lemme look it up on google and see if I find anything
    &edit http://www.amazon.com/s/?ie=UTF8&ke...=aps&hvadid=3563102695&ref=pd_sl_24ymennc45_b
  8. supaste
    20 Jun 2008
