Windows Converting video to Sony Walkman
Discussion in 'Software' started by Karol3, 14 Mar 2010.
  1. Karol3
    Karol3 What's a Dremel?
    14 Mar 2010
    I just got a new Sony Walkman NWZ-E436FRED 4 GB Digital player and I converted a few movies to it. I used Any Video Converter and it worked great but that was a trial program. So I was wondering are there any solid free programs that could convert vids to 320x240 mp4? :thumb:
  2. Landy_Ed
    Landy_Ed Combat Novice
    6 May 2009
    Handbrake no good to you?
  3. Karol3
    14 Mar 2010
    it works half the time. this is what I get when I try to convert a movie.
    ### Windows GUI 0.9.3 2008112300
    ### Running: Microsoft Windows NT 6.0.6002 Service Pack 2
    ### CPU: Intel(R) Core(TM)2 Quad CPU Q9450 @ 2.66GHz
    ### Ram: 2047 MB
    ### Screen: 1440x900
    ### Temp Dir: C:\Users\User\AppData\Local\Temp\
    ### Install Dir: D:\DVD COPY TO PC\handbrake
    ### Data Dir: C:\Users\User\AppData\Roaming\HandBrake\HandBrake\0.9.3.0
    ### CLI Query: -i "D:\DVD COPY TO PC\MOVIE\Capitalism.mp4" -t 1 -c 1 -o "D:\DVD COPY TO PC\MOVIE\Capitalism.mp4-1-1-1.mp4" -f mp4 -w 320 -l 240 -e ffmpeg -b 150 -a 1 -E faac -B 160 -R 0 -6 dpl2 -D 1 -v
    [17:38:44] hb_init: checking cpu count
    [17:38:44] hb_init: starting libhb thread
    HandBrake 0.9.3 (2008112300) - http://handbrake.fr/
    4 CPUs detected
    Opening D:\DVD COPY TO PC\MOVIE\Capitalism.mp4...
    [17:38:44] hb_scan: path=D:\DVD COPY TO PC\MOVIE\Capitalism.mp4, title_index=1
    [17:38:44] scan: trying to open with libdvdread
    [17:38:44] dvd: not a dvd - trying as a stream/file instead
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'D:\DVD COPY TO PC\MOVIE\Capitalism.mp4':
    Duration: 02:07:18.67, start: 0.000000, bitrate: 1129 kb/s
    Stream #0.0(eng): Video: mpeg4, yuv420p, 720x400 [PAR 1:1 DAR 9:5], 24000.00 tb(r)
    Stream #0.1(eng): Audio: aac, 48000 Hz, stereo, s16
    [17:38:44] scan: decoding previews for title 1
    Scanning title 1...
    [17:38:44] scan: 10 previews, 720x400, 23.979 fps, autocrop = 0/0/0/0, aspect 16:9, PAR 1:1
    [17:38:44] scan: title (0) job->width:720, job->height:400
    [17:38:44] libhb: scan thread found 1 valid title(s)
    + title 1:
    + vts 0, ttn 0, cells 0->0 (0 blocks)
    + duration: 02:07:18
    + size: 720x400, aspect: 1.80, 23.979 fps
    + autocrop: 0/0/0/0
    + chapters:
    + 1: cells 0->0, 0 blocks, duration 02:07:18
    + audio tracks:
    + 1, English (AAC)
    + subtitle tracks:
    Invalid sample rate 0, using input rate 48000
    [17:38:45] 1 job(s) to process
    [17:38:45] starting job
    [17:38:45] work: sanitizing track 0 mixdown Dolby Pro Logic II to Stereo
    [17:38:45] job configuration:
    [17:38:45] * source
    [17:38:45] + D:\DVD COPY TO PC\MOVIE\Capitalism.mp4
    [17:38:45] + title 1, chapter(s) 1 to 1
    [17:38:45] + container: mov,mp4,m4a,3gp,3g2,mj2
    [17:38:45] + data rate: 1129 kbps
    [17:38:45] * destination
    [17:38:45] + D:\DVD COPY TO PC\MOVIE\Capitalism.mp4-1-1-1.mp4
    [17:38:45] + container: MPEG-4 (.mp4 and .m4v)
    [17:38:45] * video track
    [17:38:45] + decoder: mpeg4
    [17:38:45] + frame rate: same as source (around 23.979 fps)
    [17:38:45] + dimensions: 720 * 400 -> 320 * 240, crop 0/0/0/0
    [17:38:45] + encoder: FFmpeg
    [17:38:45] + bitrate: 150 kbps, pass: 0
    [17:38:45] * audio track 0
    [17:38:45] + decoder: English (AAC) (track 1, id 1)
    [17:38:45] + mixdown: Stereo
    [17:38:45] + encoder: faac
    [17:38:45] + bitrate: 160 kbps, samplerate: 48000 Hz
    [17:38:45] dvd: not a dvd - trying as a stream/file instead
    [17:38:45] encavcodec: truncating framerate 187667 / 4500000
    [17:38:45] sync: expecting 183188 video frames
    [17:38:45] reader: first SCR 0
    4 [unknown (0x90C)] HandBrakeCLI 276 _cygtls::handle_exceptions: Exception: STATUS_ACCESS_VIOLATION
    31594 [unknown (0x90C)] HandBrakeCLI 276 open_stackdumpfile: Dumping stack trace to HandBrakeCLI.exe.stackdump
  4. Landy_Ed
    6 May 2009
    ah, is the source dvd copy protected?
  5. knuck
    knuck Hate your face
    25 Jan 2002
    FormatFactory is by far the best video/audio converting software I have found on the net so far. Give it a shot, that's what I use for everything. I even converted videos to 3gp and they worked on my crap LG Rumour phone
  6. Karol3
    14 Mar 2010
    ill give it a shot. well I use DVD43 to disable the drm.
  7. apxf8888
    apxf8888 Banned
    28 Jul 2010
    I think the video converters are all not free!
