A/V Converting WMA to MP3
Discussion in 'Hardware' started by Brooxy, 6 Sep 2006.
  1. Brooxy
    Brooxy Loser of the Game
    20 Apr 2006
    So i got a new phone today, which is an MP3 player - however most of my music collection is in WMA format, and I need it in MP3. I know iTunes does it...but I don't like itunes.
    Any idea? I don't want to re-rip all of my CD's or install iTunes :sigh:
  2. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    I would just install Itunes load library to it. Save that to a folder dlete itunes.
  3. alastor
    alastor Minimodder
    6 Sep 2004
    You could try dbpoweramp with the windows media codec plugin, always works well for just about any conversions I need to make.
  4. Brooxy
    20 Apr 2006
    Ahhhh looks good, thanks mate
    *hands over e-cookie*
  5. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    CDex will convert them I think
  6. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    fwiw, i would consider reripping any music you can rerip - crosscoding music is generally a bad thing.
    if you must, use a higher bitrate to minimise quality loss (ie, if it's a 128k WMA go to 192k mp3).
    i could go into the technical reasons behind this, but google can say it far better than i can.
  7. Sp!
    Sp! Minimodder
    6 Dec 2002
    http://mediacoder.sourceforge.net/
    But unless you have really good quality WMA's I'd re rip from the CD's as you'll get a much better result, Maybe you should consider re ripping to FLAC or something else that's lossless and then you can transcode to MP3's at any bit rate (or any other file type whit the same quality as straight from the CD) that way if you buy a device in the futre that you want a different formail or quality for you can easily transcode again
  8. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    i like jetaudio for this. it has a really nice simple gui for ripping and transcoding
