Modding Cool FANS
Discussion in 'Modding' started by Kipster, 19 Aug 2001.
  1. Koolvin
    Koolvin The Modfather
    12 Mar 2001
  2. tigermain
    tigermain What's a Dremel?
    24 Mar 2001
    You probably wouldnt, its just in a more related environment !
    And why are you in such a bad mood today ?
  3. Koolvin
    12 Mar 2001
    not a bad mood :) im never in a bad mood (hardly)
  4. tigermain
    24 Mar 2001
    We wont go back into the Coolmaster thread then !!!!!!!!
    :eek:
  5. Koolvin
    12 Mar 2001
  6. SuperScrubber
    SuperScrubber Mad Chemist.....buwahahaa
    12 Mar 2001
    ...................now children lets all play nice.................:D
  7. Phil
    Phil What's a Dremel?
    19 Jul 2001
  8. Kipster
    Kipster What's a Dremel?
    19 Aug 2001
  9. slau
    slau What's a Dremel?
    2 May 2001
    Oh that new method is pretty damn cool. Nice one!
  10. Forsaken
    Forsaken GameFaction.com
    27 Mar 2001
    Figger out who did it 1st :)
  11. Forsaken
    27 Mar 2001
    Just pulled apart an 80mm Y.S. Tech fan (FD1281255s) and an 80mm Evercool (EC8025M12S), and there a little different to the ones you did the guide with, insted of a circlip they use 2 plastic washers, and a rubber seal, and at the base of the shaft there is another rubber seal, looks like its insted of the spring which i cant seem to find, or the bearings for that matter (maybe im blind :p).
    And when you need to solder the braid to the terminal, on the above fans its covered by plastic.
    Just thought id mention it so you dont need to kill a couple of fans :)
