Coolant or no coolant additives etc? For my Mahogany Desk
Discussion in 'Watercooling' started by Huskybongs, 19 May 2018.
  1. Huskybongs
    Huskybongs Active Member
    11 Feb 2017
    Hi,
    I'm building a pretty neat desk as of now and I've never been a fan of coolant always ran pure distilled water and it has worked for years and years.
    Allthough I figured I could give it a go. What's the best coolant there is and what kind of life expectancy can I get? I wanna go for a deep blue or a clear white. Do I need some separate adhesives etc?
    System in question. Appriciating any input
  2. TheMadDutchDude
    23 Aug 2013
    If you go for premixed solutions, they typically have all of the additives required to keep the system free of growth.
  3. Big Elf
    23 Apr 2009
    I'd only consider Mayhem's for dyes.
  4. Huskybongs
    11 Feb 2017
    Are premixed solutions better in general than a concentrate?
  5. Arthur
    Arthur Comment is over there ----->
    24 Nov 2009
    In over 10+ years of watercooling, I have only ever used water that I make myself without adding any dyes. Few drops of biocide and had no problems whatsoever.
    I bought a second reservoir a few weeks back as I am adding a second loop. It was second hand and had been used with a blue liquid.
    Took me 3 days to clean it out with cotton buds and cocktail sticks. Good as new now though.
    Seen some rather nasty clogged up cpu and gpu blocks over the years with dyes.
    I am not trying to put you off as its each to their own but just get a good brand if you are going to use colours in your loop.
  6. pre
    pre Member
    24 May 2004
    Mayhem X1 clear. Cleaning out a colored dye is literally not worth it if you wish to reuse components down the road.
  7. b1g-d0g
    b1g-d0g Well-Known Member
    30 Sep 2001
    Was thinking this myself but I've decided to use distilled with biocide and a silver coil in the res.
