Cooling coolant/radiators
Discussion in 'Hardware' started by Pie_uk, 3 Jan 2007.
  1. Pie_uk
    Pie_uk British beef, in Britain
    6 Apr 2005
    hey guys, i am wanting some help with trying to decide the following >>
    go with some coloured tygon tubing and non conductive dye
    go with clear tygon tubing and coloured non-conductive water
    becuase i have never water cooled before i am to nervous to water cool with de ionized water so i have been looking at
    fluidxp extreme and innovatech ip protect,
    or shall i just use de-ioinized and some zerex/uv dye :naughty:
    please help me out
    cheers all
    also on the note of radiators, would i see an improvement from a double rad (Black ice extreme stealth) to a double Thermochill PA radiator?
    just i have heard lots of people raving about them.
    my system will be
    Intell E6600 (xeon 3060)
    X1900XTX
    and possibly a north chip cooler
  2. Nexxo
    23 Oct 2001
    You cannot use dyes with Fluidxp or Innovatek IP protect AFAIK.
    If you want to use a dye, you'll have to use de-ionised water with 5% Zerex.
    Whether you want to use coloured tubing with colourless coolant, or clear tubing with dye in the coolant is basically down to your personal preference.
    As for the rads, I don't think there will be an appreciable difference. Both are very good.
  3. airchie
    airchie What's a Dremel?
    22 Mar 2005
    Yeah, I'd just use destilled water tbh.
    I see in another thread I just replied to you were thinking of using fluorinet.
    I believe Nexxo uses it in his loop (or did) so he may be able to offer opinions on it (which I'd be interested in reading too).
    One thing is, though it may seem like a great idea to use fluorinert for the first loop so you don't fry anything, its probably not a great idea.
    Reasons being:-
    its really expensive and evaporates like crazy so any leaks due to inexperience etc will be costly.
    It finds small leaks much easier than water (due to lower viscosity IIRC).
    If you do a good leak test with water you will be safe enough.
    Even if you do leak during your test nothing should be damaged if you dry it out completely. :)
  4. Pie_uk
    6 Apr 2005
    ok thanks guys, yes it is a personal preference thing ino.
    fluid xp extreme now comes in colours, avaliable over at special tech
    i would probably use clear innovatech ip or clear fluid xp
