Hardware Cooler Master ACTS 840
Discussion in 'Article Discussion' started by Tim S, 31 Oct 2008.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. DaMightyMouse
    DaMightyMouse What's a Dremel?
    1 Aug 2008
    This case looks awesome its just the price tag thats a little out of my range. I got my Haf 932 for about 100 pounds here in South Africa which translates to about 1.6K rands if I had to go for this ATCS it would translate to about 3k rands ... ouch
  3. DaMightyMouse
    1 Aug 2008
    I was wondering if there is any way to add dust filters to the HAF?
  4. Tim S
    Tim S OG
    8 Nov 2001
    You could definitely mod your own in... I don't know what works these days, but back in the day I used women's tights/stockings and they worked very well (although you'll get a strange look when you buy them from your local store). You don't want thick tights... they need to be as fine as possible ideally. Then you literally just cut pieces and stretch them over the fans, using electrician's tape to secure them in place. I'm sure there are better options than this, as well, but that's just one for starters. :)
  5. The boy 4rm oz
    10 Apr 2008
    Now that's a case with potential. A very worthy blank canvas.
  6. Tim S
    Tim S OG
    8 Nov 2001
    It made me want to dust off my tools and get back into modding again! I think there's massive potential for some of the PC60-esq mods (and Cyprio's Apple G5 mod) to be done to this - it's a good looker to start with so you'd want to keep that intact... merely add to the design and enhance it. :)
  7. badders
    badders Neuken in de Keuken
    4 Dec 2007
    Tumble dryer sheets :D
  8. DaMightyMouse
    1 Aug 2008
    Time to raid my girl friend's closet hehehehe :)
  9. Kúsař
    Kúsař regular bit-tech reader
    23 Apr 2008
    Now that's Case!
    Given the great results & rating I bet a celebration feast took place once review was written.
  10. StephenK
    StephenK Sneak 'em Upper
    21 Dec 2006
    Any thoughts on increasing the air cooling performance? Although this looks like an opportunity for me to try my hand a watercooling maybe :)
    A truly top quality case though. Beautiful :)
  11. Baz
    Baz I work for Corsair
    13 Jan 2005
    It certainly seems that cases with side panel intakes get a huge boost in air cooling performance - the HAF 932 and the akasa Omega both use this to good effect. Cut a 230mm blow hole into that nice big side panel and i'm sure you'd see temperatures better than those we say in HAF 932.
  12. Bauul
    Bauul Sir Bongaminge
    7 Apr 2007
    That's all very well... but how did it perform in the Martin test?
  13. Guest-16
    Guest-16 Guest
    Not bad, the button is nice with an excellent click, however there's lots of wiggle that lets it down. It's a solid 8/10
  14. kenco_uk
    28 Nov 2003
    Please don't use 'off of' - it sounds like 'offal' and it ain't proper English.
    If anything, it just wants to read 'off' or 'from'.
    /grammerwtfnazi!1cheesecake
  15. zr_ox
    zr_ox Whooolapoook
    5 Jan 2005
    Well its been nice knowing you TJ09....
    I cooling performance does not bother me much since it seems well within spec, especially since this will be much quieter than the HAF!
  16. Baz
    13 Jan 2005
    the two are pretty much identical in terms of noice actually - the use of low RPM 230mm fans means all you'll really hear is the air the low rush of air into and out of the case - they're both stunningly quiet.
  17. _DTM2000_
    _DTM2000_ Minimodder
    9 Feb 2005
    Awesome, I've been hoping for a Bit-Tech review of this for a while. I thought this case looked right up my street when I first saw it and I'm glad the specs on paper reflect in the actual performance. I think this will be the case I use for my new PC in 2009. I've just got to decide if I can swallow the price, it's a bit steep for my likeing but it looks like a sound investment.
  18. Guest-16
    Guest-16 Guest
    ? How is it fail? It's not that much different to the A1 tbh.
  19. zr_ox
    zr_ox Whooolapoook
    5 Jan 2005
    Sorry but STFU.......All you ever do is moan about the orientation of the HDD rack! The only thing that is an "utter fail" is your reasoning behind why this orientation is an "utter fail"!
    So please please please stop!
  20. Baz
    13 Jan 2005
    There is nothing wrong with the drive rack. As we've told you before, we've spoken with several representatives from case manufactuerers regarding this, and they all say the same thing - orientating the drives one way or the other makes no difference. The drive cage allows plenty of space between drives for air to move, and even has provisioning for two 120mm fans to be mounted inside.
    If you have some testing or results that support your claims, then by all means present them and we'll reconsider our stance on this. Otherwise, please stop reposting the same comment over and over in case reviews - it's getting close to spam now.
    Back on topic now - This is case is awesome! seriously making me want to whip out the tools and cut a window/blow hole into those side panels - they're just begging to be modded.
Tags: Add Tags
