Hardware Cooler Master ACTS 840
Discussion in 'Article Discussion' started by Tim S, 31 Oct 2008.
  1. EsaT
    EsaT New Member
    3 Nov 2008
    You should make another CPU temperature test but make airflow guide from (for example) cardboard which forces top exhaust fans to draw air only from above CPU instead of everywhere.
    One user reported 10C CPU temp drop with such arrangement in Cosmos so uncontrolled airflow isn't minor thing.
    Big low speed fans generate more harder to hear low frequency noise which penetrates walls and structures better.
    Low frequency noise (basically vibration of molecules) might make some objects to vibrate at their resonant frequency making it audible, also size of room etc could amplify it at certain position. (try positioning speaker at different distances from wall and listen behaviour of low frequencies)
    Isn't there general rule for these situations: Not if you can stretch cables enough! :D
  2. zr_ox
    zr_ox Whooolapoook
    5 Jan 2005
    Nobody said you should not comment, they asked you to stop spamming all of the case reviews with the same groundless nonsense.
    It's not just here though, you've been spamming the Xtremesystems forums with the same rubbish, everyone over there is telling you the same though...It makes...no...difference!!!
    What nobody seems to understand is why you wont stop, to make matters worse I dont know how many of us with traversley mounted hard drives tell you that it's not a problem! However you still fail to listen and are adamant that some high tech hardware guy told you that such mounting increases the chance of failure!
    Well most modern hard disks have manufacturers warranties which state operating temperatures from 5 to 55 degrees C! You can wrap your disk in a plastic bag and it'd probably be fine! Hard disks are probably the component in your computer which require the least amount of cooling!
    Now stop the madness! Until you have some hard evidence and not just some hearsay, on second thoughts perhaps you can contact Adam & Jamie and ask them to clear this up once and for all!
  3. Bluephoenix
    Bluephoenix Spoon? What spoon?
    3 Dec 2006
    please don't, there are enough people taking their crap as scientific evidence when half of it has no science whatsoever to it.
    admittedly some of it is decently interesting, but lacks the depth required for serious testing or proof. (most likely due to their time and budget constraints, as well as requiring entertainment value)
  4. Amon
    Amon inch-perfect
    1 Jun 2007
    At work, we enclose hard disk drives in near-unvented solid aluminium enclosures and they withstand 24 hours of 50 centigrade in the oven. Disk drives are quite dandy things, until you shake them.
  5. DevonK
    DevonK New Member
    15 Nov 2008
    For those looking for a quiet case - take the review findings here about case noise with a HUGE grain of salt. The problem: as was the case with the HAF test, a passively cooled GPU was used inthe build by bit-tech. As anyone knows who's done a high end build in the last three years using a decently quiet fan on their CPU cooler, by FAR the major source of noise in a high end gaming system (aside from case fans) is the fan on any current high end GPU - it completely masks the HD and CPU sounds. So from this review, we know the case fans are quiet; but what we can't know is if the case is any good at masking fan noise from a GPU card. Other reviews of the HAF out there make it very clear that (contrary to the view expressed in the bit-tech review) that case if very noisy when used with a high end video card as its honeycombed case does nothing to muffle sound. Hopefully the 840 is better in this regard due to its more solid construction but there is no way of knowing from this review, and the two large blowholes at the top of this case could let a lot of the GPU sound escape. We will have to await other reviews before knowing; too bad given the quantitative comparisons bit-tech runs don't test for this crucial factor .
  6. Guest-16
    Guest-16 Guest
    The fact that you buy high end cards knowing what kind of noise they generate and they only kick things up a notch when you're gaming anyway - how many of us game with headphones or nice, loud speakers? (how many people own 360s and tolerate that?)
    We test the case on what the case is - we can't account for every single setup unfortunately so we rate on one uniform one to ascertain apples to apples comparatives. You have made a good point, although your wording is somewhat harsh in criticism, and we welcome your opinion. Maybe we should test an SLI setup and four hard drives in the future for larger cases to understand the vibration deadening or masking effects. Generally if you fill it with sound deadening then the case becomes an oven - so you sacrifice on cooling and a potential overclock perhaps - or if you make the sides thicker to compensate the case is so heavy you need a forklift to move it (P190 here). What's the correct answer - built like a tank and super expensive? enclosed and foaming in but very hot or ventilated and open to vibration permittivity?
    The HAF specifically is called high air flow for a reason - it's designed to cool, not to be a concrete block. The ACTS 840 is somewhere in between this - Antec P190 territory - a bit of a medium, but without the extreme weight so much and wider to make it easier to work with (I have a P190 under my desk FYI).
    If you want to work towards silence you invest in a cooling kit and the build as a whole to make it possible. This is the same as ANY build - you balance the budget according to your needs. You watercool everything and keep the large fans to a minimum or use multiple radiators, or look for alternative aftermarket coolers if possible. Vadim used to cool highly overclocked cases with tons of radiators and very quiet fans in this way and it was hugely successful (albeit expensive).
  7. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    LOL. Personally, I ALWAYS change off the stock cooler on my GPU's, and it's usually a waterblock. So, to me your argument is a moot point. Bindi's points underline that fact.
    I have nothing but confidence in Cooler Master's design team, especially when they slap the ATCS logo on it.
  8. warriorpoet
    warriorpoet New Member
    2 Nov 2008
    Personally, that doesn't matter one whit to me. What does matter is HDD mounting, since there's so little I can do to alter it. High-end GPU? It's in my loop, and 700 RPM Slipstreams are VERY quiet ;)
    I'd also like some idea of how this case responds to system vibration, since aluminum has a tendency to "hum" and amplify vibration noise rather than damp it. It's why my last three cases have been steel.
  9. DevonK
    DevonK New Member
    15 Nov 2008
    You make some good (if fairly well known) points about building a quiet(er) system. However many of us don't want the cost and hassle of building and maintaining a water-cooled system (many of which are not that quiet anyway with their radiator fans), and the current generation of top-end video cards such as the 280 and 4870 do not yet have alternative quiet air coolers readily available, so testing higher end cases for their abilty to dampen video card noise would seem a useful part of a complete test. It's highly unlikely that the typical purchaser of this case is going to use a passive air-cooled GPU - it's a high-end case and will likely house a high-end video card (none of which can be passively air cooled). And only a small minority of folk choose to water-cool. So I'm just saying "test for the typical user". A cardinal principle that applies to any usability testing is to "know thy user and his needs" and shape your evaluation protocol accordingly. Most of us use our computers for purposes that go beyond gaming, and we don't want to have speakers blasting or headphones on all the time to mask system noise. So knowing the balance between GPU fan noise damping capacity and heat dissipation efficiency for a given case is valuable information for the prospective buyer.
    I do appreciate your efforts to quantify heat dissipation efficiencies in your case comparisons, that is certainly a big step up from most case testing seen on the web.
  10. Tim S
    Tim S OG
    8 Nov 2001
    I must say that I've used high-performance dual radiator watercooling setups with upwards of ten 120mm fans in the system that were literally inaudible - the loudest thing was the power supply and that wasn't exactly loud by any stretch as it was a so-called 'silent' unit (no, it wasn't silent, but it wasn't noisy and was inaudible above background noise at approx 1m). Those that turn the fans up on their watercooling loops don't actually want silence, they're after even higher performance. :)
    The only time a watercooling kit I've used actually made noise that stood out above background noise was when I was using one of those pre-built 'watercooling in a box' kits. If you spend time investigating and planning a good watercooling loop, it will be silent if you want it to be.
  11. Guest-16
    Guest-16 Guest
    I'll put it this way - we don't recommend something unless we genuinely want one, and we were fighting (drawing straws) about who was going to keep the 840 until Cooler Master decided it wanted it back :(
  12. Tim S
    Tim S OG
    8 Nov 2001
    fighting sounds better... Harry wasn't actively involved though, because he was humping the Sumo beanbag (see left).
  13. E.E.L. Ambiense
    26 Jul 2007
    ^LOL
    Hahaha, that's good to hear, Bindi. I' really seriously thinking of picking one up. Not just because I want to, but because I need to. I'm glad you guys give it the stamp of approval too, because that will make my decision even easier! :)
  14. Csaba73
    Csaba73 New Member
    21 Nov 2008
    The case is beautiful, does anyone know where to buy one - I have been looking around various European eShops like Novatech, but nothing. Thanks a lot,
    csaba
  15. Guest-16
    Guest-16 Guest
    I've emailed our CM contact to ask where in Italy you can buy from :)
  16. Guest-16
    Guest-16 Guest
    ATCS 840 is not available in Italy just yet, according to CM Europe.
  17. Ironpipe
    Ironpipe New Member
    3 Jan 2009
    I am totally surprised that I have not read anything about the location of the Power Supply. It was the first thing I noticed. It hit me like a ton of bricks. What ever happen to that basic law of physics stating that heat rises? I am sure that some of the heat that is generated by the power unit will dissipate to the rear of the case, but most will be drawn upward across the Mother Board and its components by the top exhaust fans. The case temperature, CPU, Ram, Video Card, etc, will therefore be exposed to higher (unnecessary) temperature.
    At present I use a Cooler Master CM Stacker 830 ATX Tower Case. I removed the 4 fan side door and install a home made quick disconnect liquid cool system that allows me to add or remove any the liquid from any component at any time within seconds. The entire system is enclosed in the case. If this was an inch wider it would have made it a perfect Case.
  18. glenster
    glenster glenster
    20 Dec 2008
    Please review the Coolermaster Storm Sniper and the Silverstone Raven RV01.
  19. Guest-16
    Guest-16 Guest
    Can you wait until tomorrow? :naughty:
  20. badders
    badders Neuken in de Keuken
    4 Dec 2007
    LOL
    No, dammit! Get typing!
    Jokes guys - You lot do a brilliant job!
Tags: Add Tags
