Case Mod - In Progress Cooler Master ATCS-840 TRON EVOLUTION MOD
Discussion in 'Project Logs' started by pichicho, 19 Aug 2011.
  1. pichicho
    pichicho New Member
    16 Aug 2011
    Hi guys I bring a new modding this time will Evolution Tron, and the case will be a Cooler Master ATCS-840; This is a very roomy aluminum case which will make the following changes:
    • Cut a window in the side and install a 5mm acrylic.
    • Modification of the fan grill on the bottom and back. (Possibly also the top)
    • Convert the entire exterior carbon fiber type.
    • Installation of Tron Light Strip type on the sides.
    • Installation of RGB lighting (LED's with the full range of colors) by remote control.
    • Dual 850W power supply. Each.
    • Change the LEDs of the fan's white color and do not come with LEDs will adapt them.
    • Install rack's for two SSDs.
    And other things that go out on the road if the muse inspires me. (Suggestions accepted)
    Well some pics of the case and a small advance on the right side panel to give an idea of what the Mod.
    Preview of the side panel and some applications in acrylic.
    Hope you like it and leave your opinions.
    Greetings and good Modding
  2. pichicho
    pichicho New Member
    16 Aug 2011
    Hi Guys I leave more progress here:
    So you will see the case, carbon fiber type.
    Is a video of how to install:
    Some of the fan's.
    Also change the CrossFire cables
    The two power suply.
    Here you can see the Cable Management and adaptation to enable them to operate two power suply.
    It was made a cover for the back of the bays there be installing two SSD drive.
    The controlled RGB LED's and remote control.
    Fan's for the radiator in Push / Pull
    A test of how they will be Led Strips (not yet defined where they go)
    Well I hope you like it and leave their opinions and ideas.
    Regards
  3. pichicho
    pichicho New Member
    16 Aug 2011
    Hi sorry for the delay but I was short of time for various events and the opening of the store, so I return to modding and I bring you photos of the final hardware already mounted and some photos of the event which introduced the PC. And the simulator that I manufactured.
    Well I hope you enjoy and leave comments.
    Regards
