Case Mod - In Progress Cooler Master CM 690 III : Modded Edition
Discussion in 'Project Logs' started by k-limes, 25 Nov 2013.
  1. k-limes
    k-limes What's a Dremel?
    22 Nov 2013
    Hello everyone,
    I open my first workblog on this forum with my latest achievement dated on a Cooler Master CM690III.
    This mod was created for a contest I joined, so I can tell you about it ;)
  2. Combatus
    Combatus Bit-tech Modding + hardware reviews Staff Super Moderator
    16 Feb 2009
    Welcome to the forum k-limes. I've seen this project and pretty sure everyone here will think it's spectacular too!! :D If you can please post some in-progress shots ASAP that would be good as the project log section needs work photos ;)
  3. k-limes
    22 Nov 2013
  4. k-limes
    22 Nov 2013
    Hello everyone
    Added pictures of modding CM690III second post ;)
  5. jimbaw
    jimbaw What's a Dremel?
    8 May 2014
    magnifique! comment tu as fais les cables?
  6. k-limes
    22 Nov 2013
    Salut ;)
    Les câbles sont fait à partir de tige de laiton ;)
    The cables are made ​​from brass rod
  7. jimbaw
    8 May 2014
    ok thanks for the answer. od you have a tutorial or a detailed build log anywhere?
  8. k-limes
    22 Nov 2013
    If I have a more detailed worklog but on other forums!
  9. WaRn00b™
    WaRn00b™ bit-tech addict
    14 Jan 2013
    Holy sheeeeeaaaaaaat..... that looks damn nice... well done!!
  10. k-limes
    22 Nov 2013
  11. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    Got any links to said build logs? I love the result, but seeing what it took to get there is all the better!
  12. k-limes
    22 Nov 2013
    I can possibly share the stages of this worklog if you wish it, I would do that in the week ;)
  13. Z0DIAX
    Z0DIAX bending alloys
    26 Jul 2013
    superbe build, love all the small detailles that make it a sweeeet mod, the green and white are in perfect balance with the black. and the wireing is epic... cuddos to you sir
  14. k-limes
    22 Nov 2013
    Thank you for the compliments ;)
    Merci pour ces compliments ;)
  15. lowfat
    lowfat Minimodder
    4 Jul 2013
    The wiring is brilliant. :rock:
