Hardware Cooler Master CM 690
Discussion in 'Article Discussion' started by Tim S, 29 Nov 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. DarkLord7854
    DarkLord7854 What's a Dremel?
    22 Jun 2005
    Ooh.. I've been wanting a new, cheap, case. Looks like that might be it, there's a 40$ discount going on at newegg off the retail 79$ price
  3. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
    :O Worth it, definitely IMHO
  4. DarkLord7854
    22 Jun 2005
    Would be nice if it had a clear side panel, but ah well, can't have everything I suppose. The watercooling holes are a real plus, as is the bottom mounted PSU. I'm so tired of having my PSU at the top. Bleh.
    Guess adding a side clear panel and re-mounting the power/reset buttons and lights would make for a nice and neat weekend mod project I spose though
  5. Fozzy
    Fozzy What's a Dremel?
    25 Jan 2005
    Does the 80mm fan behind the mobo do anything? I've always wondered
  6. CardJoe
    3 Apr 2007
    There wasn't one in when we tested, but the idea is to cool the back of the CPU I think. The fan is exactly where the CPU goes.
  7. samkiller42
    25 Apr 2006
    I've seen this case in person, and it is a nice looking case. Nice review as usual guys, cheers.
    Sam
  8. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    Nice case for modding, would a dual 120mm radiator fit in the top (inside) or do i have to place it on top with the fans on the inside in push mode. Also there looks to be room on the bottom next to the psu to fit a single 120mm radiator. Dish the hd tray and place pump/reservior there and move hds to 5 1/4 slots with some nexus disktwins
  9. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    What do you mean? There is a 120mm intake fan right in front of the HDD rack. Good cooling in my book. Its a nice case but sadly it costs 85€ around here which doesnt bring it in the value sector at all as i can pick up better cases (LL, Silverstone) for 90-100€. If the price translation would be better i would buy it.
  10. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    Great, and just in time for Christmas too. I hope that Father Christmas hasn't got me anything yet...
    On the cooling front, how does it manage record a lower CPU temperature when the GPU stress test is going than when it is idle? It seems a bit counter intuitive. (along with have a case temp below room temp, although that probably the thermometer)
  11. enughhh
    enughhh What's a Dremel?
    18 Sep 2007
    There are actually many extra screws included, they are screwed in place near the back of the 5.25 drive cage.
  12. KMS-oul
    KMS-oul You think you know me.
    1 Aug 2002
    Looks like a decent case for watercooling without breaking the bank.
  13. Max Spain
    Max Spain What's a Dremel?
    18 Jul 2007
    I love this case and I completely agree with the review. Its only fault is that it isn't as sturdy as other cases, but they had to cut costs somewhere. I am planning on putting my next all Intel system in that box. I'd sure love to see that case filled with fans and watercooling doodads...
  14. Guido
    Guido What's a Dremel?
    27 Jan 2004
    According to Slickdeals.net, ZipZoomFly has this case for $40. It comes with a $30 MIR making it $10. Pretty good deal, I think.
  15. sl1xx
    sl1xx What's a Dremel?
    12 Apr 2006
    i have the case and im pleased with it run cool and silent,i think he was a bit harsh with the build quality tho defo deserveda bit more great case bang for buck.
  16. DarkLord7854
    22 Jun 2005
    Only problem I have with it.. I have my watercooling sealed with silicone and my reservoir is a 2.5" bay mounting one.. and I get the feeling things won't fit too happily.. Then again, if I get it off ZipZoomFly the case is only 10$ hmmmm.. Tempting
  17. Dreaming
    Dreaming What's a Dremel?
    31 Jan 2007
    I'm thinking of upgrading to this from an Antec P180. I know the noise is a bit more, but the P180 is far too heavy and far too difficult to upgrade! Especially the hard disks!
    Difficult to decide between cases like this and the anubis though. Anubis has the + that it seems to have nice build quality, but this is cheaper and lighter. But this is made of plastic in parts!
    Anyone who has this who has had a P180? Or am I the only one insane enough to take this upgrade path?
  18. djDEATH
    djDEATH Habari gani?
    23 Mar 2006
    "On the cooling front, how does it manage record a lower CPU temperature when the GPU stress test is going than when it is idle? It seems a bit counter intuitive. (along with have a case temp below room temp, although that probably the thermometer)"
    i noticed that too, how is the CPU cooler when stressing the GPU then when the PC is idle.
    in the spirit of the way the article was written, get those thermometers back out, i demand a retest!!!
    lol j/k.
  19. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    The grommets only accept up to 1/2" OD tubing, which is a bit limiting.
    There's no fan, and there is not enough room for even slim fans, nor are there mounting holes. To the best of my guessing, I'd say that the holes are for ventilation only, and that the recess and two screws are meant for a filter or something like that.
    If you're creative, I'm sure you can fit a 120mm rad at the bottom. There are mounting clips which are too large to secure a 120mm fan, so perhaps it's for a 120mm radiator or slightly larger fan.
    As for the top of the case, there may be room for a 240mm radiator inside the case, and two 120mm fans above the steel grill but below the top black grill. It'll be tight though. You may be better off mounting the rad on top, but if you put the fans inside, they're going to see a lot of airflow restriction unless you cut out the black meshing on top of the case.
    One thing I really don't like about the cas is that the HD mounts are plastic and feel really flimsy. Then again, I suppose it's necessary for the trays to be toolless.
  20. DarkLord7854
    22 Jun 2005
    The HD rack can't be rotated right?
Tags: Add Tags
