Hardware Cooler Master CM 690
Discussion in 'Article Discussion' started by Tim S, 29 Nov 2007.
  1. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    Correct.
  2. Archtronics
    Archtronics Well-Known Member
    27 Jun 2006
    you cant do that there not enough space and clip at the bottem is for a 140mm fan
    I just got this case Im pleased:)
  3. badders
    badders Neuken in de Keuken
    4 Dec 2007
    I'm looking forward to getting mine on 8th June!! - :D
  4. Amon
    Amon inch-perfect
    1 Jun 2007
    My co-worker brought it in to work today. It's okay. Study. Cheap, relatively, for what you are getting. But CoolerMaster has usually erred on the stale side of dressiness, for me. It just doesn't have class.
  5. dhaval070
    dhaval070 New Member
    9 Mar 2011
    I just bought cm 690 after reading some reviews. But I am disappointed buy its poor quality plastics front panel.
    I had to took it off for installing dvd drives. After getting it off, I realized I broke some of its connectors to case. Don't know whether it will fit it back again or not.
    Whey didn't they put some satisfactory quality panel?. Its too delicate and prone to break while taking it off.
    This is my first and last buy of cooler master brand.
Tags: Add Tags
