Case Mod - In Progress Cooler Master Cosmos II MbK...Final pics!!!
Discussion in 'Project Logs' started by kier, 2 Jan 2012.
  1. kier
    kier -----------------
    1 Mar 2011
    Sponsered by:
    Hi my modding friends,
    A new year begins, so a good start in terms of a new modding season
    With a brand new case .... which is released right now, the Cosmos II
    The new flagship of Cooler Master.
    The hardware which comes in it is not known yet for sure, but it is certain that an x79 mobo and a number GTX580 GPUs comes in
    And offcourse watercooled.
    The color combination is going to be black, gray and white
    The package was brought a month ago, the deliveryman cursed me :)
    What a case and what a weight, unbelievable. My wife was pissed and called me some names I didn't heard before
    So I needed to make space in my workshop to properly view the case.
    The package:
    First unpacking which quite a operation turned out to be
    And here it is the great Cosmos II
    Lots of case with a lot of space, really a true pleasure to mod this one
    Cooler Master Raymen, Ruud and Marco and of course anyone who makes this possible ... Thanks!
    And then moved it straight to my workshop to view and show interior
    First some specifications:
    -Exterior Material: Aluminum, mesh, synthetics
    -Interior: Steel alloy, plastic, rubber
    -Dimensions: 344 (W) x 704 (H) x 664 (D) mm / 13.5 x 27.7 x 26.1 inches
    -Weight: 22 lb kg/48.5
    -Maximum compatibility CPU cooler height: 190 mm/7.48 in.
    -GPU-Length: 385 inches mm/15.15
    -Type-M/B: Micro-ATX, Micro ATX, E-ATX, Extended ATX, SSI CEB, SSI EEB
    Once dragged in my workshop and opened it immediately, I noticed how much 3.5 Drive Bay are in it
    less than 13 pieces in total (2 from X dock, Mid cage for 5 HDDs, bottom cage for 6 hard drives)
    The middle bay has room for 5 HDDs
    In the lower HDD bay there's room for 6 hard drives which is hidden behind a beautiful fan bracket with
    2 x 120 mm fan, 1200 RPM, 17 dBA
    And here there is room for 6 HDD's
    The PSU has shifted back for some extra space inside
    And is raised a little
    At the front there is space for two HDDs through the X-dock and there are three 5.25-inch drive bays available
    Below this compartment, behind the mesh part there is one 200 mm LED fan, 700 RPM, 19 dBA (converted from 120 / 140 mm)
    And below that there is still room for a 120mm fan for the airflow trough the lower HDD's bracket
    The back has room for a 10+1 Expansion Slots
    http://i759.photobucket.com/albums/xx233/kier1976/Cosmos%201/DSC05678.jpg[/IMG
    And a 140 mm fan, 1200 RPM, 19 dBA comes with it to the rear
    [IMG]http://i759.photobucket.com/albums/xx233/kier1976/Cosmos%201/DSC05679.jpg
    At the top is a lot of space under the mesh
    This cover is very easy to remove with a screw, and below is enough space for 3 fans and wiring
    There also would fit a 360 rad but for that there are some adjustments needed.
    And it comes with a black 120 mm fan, 1200 RPM, 17 dBA
    Also on the top there is a sliding panel. Below that there is a control panel with 7 functions
    More about this in the next update
    At the front there is the I / O panel with 2 xUSB 3.0, 4 x USB 2.0, 1 x e-SATA and audio in / out
    And there is very good tought about the cable management
    With enough holes
    I could go on an d on about the case but..... now it's modding time
    I removed the top mesh and made ​​a number of strips.
    Which are directed obliquely backwards, this is still a rugged design and has yet to be finished ;)
    Cut out the fan controller carefully
    Here is coming a slot loader DVD or Bluray.
    For measuring I used this one .
    And made a slot for it
    Where before was the sliding panel I cut and bent a piece of aluminum
    Which is placed like this
    And made the slot for the slot loader drive
    I hope this is a good start of the new year for you ... for me it is:)
    More to come!!!
  2. KidMod-Southpaw
    28 Sep 2010
    Awesome! Great start! Love the case, can't believe you got it so soon.
  3. Pranja
    Pranja Blackwolf
    18 Dec 2011
    How did you get this case???
    It is not even listed on CoolerMaster website.
  4. kier
    1 Mar 2011
    Thanks you guys... and it was released exactly at 00:00
  5. enormous
    enormous What's a Dremel?
    28 Apr 2010
    Probably He got from them? :)
  6. Parge
    16 Jul 2010
    That case is so nice, its almost a shame to mod... but I can't wait to see what you do!
    How about a WC 7970 with a massive GPU Core overclock instead of a 580?
  7. kier
    1 Mar 2011
    I have 2 gtx580 now and maybe 3 for this build
  8. SilveR_172
    SilveR_172 Minimodder
    24 Nov 2011
    OH MY GOD , im in love !
  9. Moddingboy
    Moddingboy What's a Dremel?
    19 Jul 2011
    Congrat for the brutal case! :jawdrop::rock:
  10. Pranja
    Pranja Blackwolf
    18 Dec 2011
    This is epic case,and it will become unmortal mod.
    Respect!!!!
  11. bulldogjeff
    2 Mar 2010
    I like where you're going with that top panel. I'll be keeping an eye on this one.
  12. weatherdown
    weatherdown What's this button fo......
    27 Dec 2011
    Following this one.. already hooked!!
  13. dmcgrath
    dmcgrath Master of Pancakes
    14 Aug 2011
    I've got to copy everyone else here and be happy with what you've begun. Good luck on your mod.
    I'll start posting mine up here soon!
  14. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    very nice case!!! i feel some chest-ache when i saw pics of reaping such beauty apart... i hope result would be good!
  15. KidMod-Southpaw
    28 Sep 2010
    Kier should make case mods for other people and sell them. And make MBK one of his best sub brands for cases, going off your previous MBK mod, this will be incredible!
    Coolermaster set a very high bar for 2012 with this case, can you set a very high bar for modding?
  16. kier
    1 Mar 2011
    Thanks y'all, I won't let you down
    @KidMod lol, I've allready started to place the "MbK" logo in some mods now ;)
    Coolermaster has really raised the bar yes, I hope I can do this also
    For that Ill need your feedback my modding friends ;)
  17. L1U
    L1U Minimodder
    1 Sep 2011
    epic case+epic modder=got to follow
    good luck with this new one ;)
  18. kier
    1 Mar 2011
    Just to compare the size of this beast :D
    And next to some other cases
  19. alain-s
    alain-s Minimodder
    12 Jan 2011
    Looking forward to this build Richard I hope u make something unique for this case. But by the first post u already had a good start with the fins on the top of the case:D
  20. Vetalar
    21 Jun 2011
    that corsair boys really looks like a kids compared to BEAST
    *watching*
    *thinking that it's almost time to abandon scratchbuilding and move to that brilliant cosmos2*
