Case Mod - In Progress Cooler Master Cosmos II MbK...Final pics!!!
Discussion in 'Project Logs' started by kier, 2 Jan 2012.
  1. RedManc
    RedManc What's a Dremel?
    30 Jul 2011
    Great update, the acrylic motherboard tray is a nice touch, is it secured by the original motherboard tray standoff holes ?
  2. Kyukuru
    Kyukuru What's a Dremel?
    20 Jan 2012
    Lovin the vent design on top :)
  3. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    it looks very good :), cant whait for more updates :)
  4. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Kier, this looks awesome.
    As you know I'm quite keen on getting details on how you did that luminous panel for the floor - and I'm not that much wiser after having read this update.
    Which is why I created this thread tonight: http://forums.bit-tech.net/showthread.php?p=2958528#post2958528
    Hopefully, I'll get some answers that I can use ;)
  5. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    Looking excellent up to now mate.
    Loved the last mod and this is looking like it's going to be better.
    Keep up the excellent work.
  6. kier
    kier -----------------
    1 Mar 2011
    :thumb:
    I''m also very pleased with the fans, think this was a good choise :rock:
    no, it's resting on the mobo tray for now
    Thanks :thumb:
    This week the EK products should be coming in...so more updates coming up
    I will dedicate a small update to this..coming right up ;)
    Thanks Damien :)
  7. fireisdangerous
    fireisdangerous What's a Dremel?
    2 Sep 2011
    For the cover I sawn a piece aluminum and marked it
    Bent it
    Cut out the Fanholes again
    Hi do you have a template for the fan cut out.
    Tony
  8. Nutman
    21 Oct 2008
    Sweet! Can't wait. ;)
  9. KidMod-Southpaw
    28 Sep 2010
    Why, and how did I miss this!? Great work!
  10. kier
    1 Mar 2011
    Sorry, no template. Just used the original fan cover from the Cosmos
    It,s not to difficult: put white sheet on the bottom from the original midplate and lifted the acrylic 4cm up, but i will show some pics ;)
  11. kier
    1 Mar 2011
    Sponsor Update !!!
    Hi fellow modders.
    It took a while since the last update, but today I have received a lot of watercooling products
    What would it be... a lot of boxes ;)
    To begin EK-PSC Fitting 10mm - G1/4 Black
    Also the EK-PSC Adapter 45° G1/4 Black
    and some beautiful EK-PSC Adapter 90° G1/4 Black
    A great CPU block: the EK-Supreme HF - EN
    and two EK-RAM Dominator X4
    For the 2x ZOTAC GTX580 gpu's iv'e got 2x a EK-FC580 GTX+ - EN
    Also with two EK-FC580 GTX Backplate - Black
    2 great tops with res: the EK-DDC X-RES 140 - Acetal
    To cool everything I ordered 2x EK-CoolStream RAD XT (240)
    For the top of the Cosmos I''m gonna place a EK-CoolStream RAD XT (360)
    And for the sabertooth board iv'e picked the EK-MOSFET ASUS X79
    Another great sponsor for this build is...... ZOTAC
    For this build I may use 2 x the ZOTAC GTX580 1536M 348BIT DDR5
    Some specs:
    Specs:
    Chipset :
    -Chipset Manufacturer NVIDIA®
    -GPU GeForce® GTX 580
    -Core clock 772 MHz
    -Stream Processors 512
    -Shader Clock 1544 MHz
    Memory :
    -Memory Clock 4008 MHz
    -Memory Size 1536MB
    -Memory Interface 384-bit
    -Memory Type GDDR5
    Chris, Craig and Carsten Thank you again for these great cards :)
    It's ashame that I need to undress the cards, but it needs to be done ;)
    And placed the EK-FC580 blocks
    Placed the backplates
    That's it, tomorrow more about the other blocks
    L1U likes this.
  12. Nutman
    21 Oct 2008
    Ooooook. I just wet myself.....
  13. bulldogjeff
    2 Mar 2010
    Nice kit, going to be awesome. I use the EK coolstream rads myself and they are excellent.
  14. kier
    1 Mar 2011
    Be sure to do a leaktest before using ;)
    They certainly are excellent :)
  15. Sarakon
    Sarakon The German
    11 Feb 2011
    Its so pretty!
  16. r1sKas
    r1sKas Orange or White? Lets mod!
    22 Jan 2011
    Those GPUS will rock so hard =P
    Regards
  17. opelgt
    opelgt What's a Dremel?
    2 Dec 2011
    exellent parts, excellent project:thumb:
  18. kier
    1 Mar 2011
    As promised, all the WC in place.
    The mosfet block:
    Next the Supreme HF.
    After that the RAM coolers
    Placed the 2 ZOTAC GTX580 GPU's
    Looks good ;) Placed everything in the Cosmos II
    And installed some fittings
    Now everything is in place it's time to mod again...to be continued :)
  19. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    That's some motherf***ing BLING you got going there! :thumb:
    Well deserved man! :)
  20. kier
    1 Mar 2011
    Thanks Angel ;) I must admid....I wet myself after installing the blocks:D
