This might just one of the best water cooling jobs around, it looks seriously cool already. I just can't wait to see this lot with juice pumping through it.
Looks really Awesome man! I love the case mabey i buy one myself it's so clean and nice! ;d This is a very awesome and clean beautiful build great job!
My thoughts of this thread as I go from page to page: Very jealous, congratulations - the mod looks stunning so far.
thanks y'all for the comments and pics Been playing with the tubes, but Im not so excited about the RAM->Mosfet connection what do you think?
It looks fine, but yes, the MOSFET<>RAM block connection looks a bit off. So, here a suggestion - I hope a written suggestion will suffice. Add a 90-degrees fitting in the top of the RAM block - add another 90-degrees fittting to that one and turn it until it points towards the MOSFET block. Now, add a 90-degrees fitting to the MOSFET block and connect the 2 blocks with a small piece of tubing. Not sure of the length of the fittings will make this solution usable, but I guess it's worth a try?
I missed this one which is strange as im a Kier fan! Read it all... Result? LOVE IT! Awesome work dude, subb'd!
Thanks Nutman I was also thinking about a 90 on the RAM and a 90 on the MOSFET. But the distance is to small to add a tube between them, so maybe with some extenders under the MOSFET 90 degrees fitting, so it will be then the same level as the RAM. All connected with a Bitspower crystal link Thanks
Update!!! Had some fun these days with cutting and sawing in the Cosmos: Hole for a straight Fill-Port and also a slot for the fitting of the pump. Holes for the gpu, s in-and outlet A hole for the wiring of the gpu, s And adjusted the slot for the sata Did the same thing for the 24 pins powercables. I also made a hole in the side of the 5.25 bay And made 2 fill-ports. And at the bottom of the 5.25, I have made a large hole for the in and outlets of the reservoirs, etc.. All this I have covered with U-channel edge from Mnpctech. Furthermore, did some nice things with the pump / reservoirs. All with fixed tubes More on this later. I also started with the cables. For the GPU power, I have marked some holes. Pre-drilling with 1.5mm 3mm And 4.5mm This is enough to go through with a sleeved wire. For the GPU power I used extensions And sleeved it in 4 colors. Black, titanium gray, gray and white Other side still loose One by one put the male connector through Did the same thing for 24 pins cable. And placed everything. One gpu have to wait ( need more heatshrink)
Looks nice man! You can use a 2.5 mm drill if you apply heatshrink after you put the wires trough the holes I did that on PC-Beto
