Case Mod - In Progress Cooler Master Cosmos II MbK...Final pics!!!
Discussion in 'Project Logs' started by kier, 2 Jan 2012.
  1. kier
    kier -----------------
    1 Mar 2011
    Thanks y'all
  2. Phyonics
    Phyonics What's a Dremel?
    4 Oct 2011
    Looking sweet :D
  3. Noob?
    Noob? What's a Dremel?
    18 Oct 2009
    Thats one sweet case, if prices come down, I'm snapping one up!
    Builds looking good mate!
  4. kier
    1 Mar 2011
    Second loop ready without any major problems
    David likes this.
  5. SilveR_172
    SilveR_172 Minimodder
    24 Nov 2011
    Would have gone with black in the 2nd loop , But thats all good project , Like it alot , you got it all up and running now ?
    benchmarks ? :p
  6. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Wonderful, wonderful.
    What tube is that?
    EDIT: Nevermind... found the answer by actually READING the worklog. What gives???
    How does it hold up when the fluid heats up? You make some pretty tight bends in some of your builds. Ever had it kink up on you when the fluid gets hotter?
  7. kier
    1 Mar 2011
    Not ready yet, need to do the front, place a window in the sidepanel and some small stuff.
    I specially didnt use the tygon tube (kinks easily), but some with better stiffness. so hopefully this will work :)
  8. kier
    1 Mar 2011
    Tonight I spent some time to the front. I changed the plan to put the usb and other stuff into the front regarding the looks and the space behind the panel.
    I think this looks better now without the, usb stuff and without the touch buttons from the Aquaero. These doesn't look good and do not work properly in my opinion
    So i've cut 3 pieces of 3mm acrylic. The first one looks like this
    And two of them like this. One of them with a smaller recess for the display
    Everything put together
    The touch buttons I do not need because I can set everything with the remote control. And once set I usually do nothing more with it, just look at the temps. The remote has a good range like this, so it's okay
    Placed in the Cosmos
    Power on
    I doubt whether I'm going to put black or carbon on the acrylic.
  9. Foregasm
    Foregasm What's a Dremel?
    3 Apr 2012
    Absolutely beautiful. You are a true modding genius.
  10. kier
    1 Mar 2011
    Thanks m8 :blush:
  11. David
    7 Apr 2009
    Lovely build. Your cable management is stunning.
    I too was wondering about the tight bends in the tubing - which looks great BTW. Have you had any experience with Tygon laboratory grade tubing?
  12. kenco_uk
    28 Nov 2003
    So crisp! I love the individual holes for the cable management, just so over the top :)
  13. dirky90
    dirky90 Minimodder
    19 Mar 2012
    kier - a quick question mate, how do you keep all the cables parallel without any zip ties or anything?? my cables always seem to do there own things.
    cheers
  14. kier
    1 Mar 2011
    Thanks Spreadie, Only experience is with watercooling. But for this build i've ordered 3 brands.
    Feser, Masterkleer and Tygon for testing the curves. Feser was the one with the most stiffness
    Thank you,
    Do you mean the Sata, GPU or 24pins cable? The Sata is done with zip ties behind the mobo tray, the gpu and 24pins are holding the parallel position because the individual holes. Straight lines from hole to connector.
  15. kier
    1 Mar 2011
    The wurst thing happened to me .... lost the flat cable connecting the PCB push button and the controller.
    In the beginning I was thinking that I must put the flatcable somewhere save before I lose it.
    So I've lost it :(. Fortunately there was Ruud from Coolermaster, who still has parts of the Cosmos
    Cooler Master Europe Store for all your spare parts.
    Ruud... thanks man!
    And everything is online again
    Inverse color display is a nice thing
    slide panel closed again, nothing to see anymore
    Cable management is still a big mess, but this is how I placed the controller
    This will become more organised ​​;)
    Drilled a hole for the switches and HDD LED
    And I have cut a 3mm black piece of acrylic to make a cover for the side bay, I don't like holes and slots :) So this will disappear.
    Made a second layer and cut out the form of the CM push buttons.
    Placed the first layer back
    Second layer on top
    Past some black film on the second layer
    And the result
    Nice, tight and the good color.
    I also been busy with the XL window for the Cosmos. What appeared to be quite a challenge because lots of plastic and little space
    The acrylic window I've made ​​1cm larger as the existing hole.
    Need to put more pressure on the edges , but this is how it becomes
    For pasting the metal cover back on the plastic, I used contact adhesive. This is because I don't have to much space for double sided tape, and it just needs to be good. Placed everywhere clamps and other stuff, which will stay on for a night. And need to make the inside a bit nicer. Ofcourse after installing the window wanted to see how it looks.
    And also have been playing with the enlightened midplate for some nightshots. I'm also thinking to put some lights in the midsection or top.
    That's it for now...Grtz.
    jhanlon303 and Nutman like this.
  16. Nutman
    21 Oct 2008
    +1 rep for using the word "wurst"!!! ;)
  17. jhanlon303
    7 Sep 2006
    +rep
    john
  18. wratterus
    wratterus What's a Dremel?
    2 Jun 2011
    So clean, looks fantastic. :D
  19. kier
    1 Mar 2011
    :lol: :hehe: :clap: Thanks for the rep
    Thanks John :thumb:
    Have change the front a little bit. The made the white acrylic black. Hope you like it ;)
    Phyonics likes this.
  20. Overminde
    Overminde What's a Dremel?
    15 Sep 2011
    Wonderful build this is looking just great
