Hardware Cooler Master Cosmos S
Discussion in 'Article Discussion' started by Tim S, 22 Feb 2008.
  1. rdhir
    rdhir What's a Dremel?
    1 Oct 2007
    Shorting motherboards with no explanation can often be fixed by the judicious use of paperwashers. Try above and below the screw holes. I find stick glue quite effective for low adhesion until screwed in place. Buy from maplin in packs of 50.
  2. HandMadeAndroid
    HandMadeAndroid That's handy.
    18 Feb 2005
    Interesting side fan design, apart from that it's Samsonite suit case, just needs to be painted pink and have some little wheels.
  3. TheLostSwede
    TheLostSwede What's a Dremel?
    12 Sep 2005
  4. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    :confused: Um, I'm sure it fits triple rads, there, man. It's common sense. Just look at the layout. If it has triple 120's up top, it'll fit a triple rad. You obviously lose the top IDE bay, but there's plenty of others.
    Besides, the review states it specifically:
    Off-the-shelf kits like the Aquagate just don't take the place of a nice custom set-up.
  5. Ownzyouall
    Ownzyouall What's a Dremel?
    6 Jan 2008
    NICE!! they finally made one in black.
  6. Draculea
    Draculea What's a Dremel?
    7 Mar 2008
    Thermochill PA120.3
    I can confirm it will not fit the PA120.3, neither the PA120.2. It will fit the PA120.1 but i have not tested it.
    Both radiators have enough room to fit the case the problem is the distance between the fan holes. Thermochill uses weird 24.5mm (because of the stupid shroud) between the holes of the fans making the whole thing much longer than any triple radiator.
    I can confirm it will fit just fine an Alphacool Extreme Triple Rad. I haven't measured the distance between the holes but it looks like a standard 15mm. So you will be able to fit any Black ICE rad. Thermochill is 24.5mm apart and Swiftech is 19mm apart so these 2 are out of the question.
    Also you will need longer screws than the ones provided by the radiator manufacturer.
  7. Koradhil
    Koradhil What's a Dremel?
    9 Nov 2004
    It will at least fit the PA120.2 if you mount it with only 4 screws (1 fan) instead of 8. I did the same for mounting a Black Ice Pro 2 inside a regular Cosmos (where the top fans are normally a couple cm apart).
  8. E.E.L. Ambiense
    26 Jul 2007
    Yeah, as I was expecting looking at the specs and the manufacturer pics of the case. I figured they wouldn't accommodate a Thermochill without additional modding, but it certainly looked to take Black Ice footprints out of box.
  9. geo139
    geo139 What's a Dremel?
    19 Jan 2008
    Radiator compatibility:
    Radiator Compatibility:
    HWLabs BlackIce GT Stealth III
    HWLabs BlackIce GT Xtreme III
    HWLabs BlackIce Pro III
    HWLabs BlackIce GT
    Watercool HTSF 360
    XSPC RS360
    XSPC R120-T
    Aquacomputer Airplex Evo
    Aquacomputer Airplex Pro
    Alphacool NexXxoS Pro III
    Magicool Aluminium 360
    Magicool Xtreme 360 Radiator
    Magicool Slim 360 Radiator
    Not Compatible:
    Thermochill PA120.3
    Swiftech MCR320 QP 360
    from: http://www.watercoolinguk.co.uk/catalog/product_info.php?products_id=835
  10. tonschk
    tonschk What's a Dremel?
    31 Jul 2008
    cannot find the way to delete this post
  11. Dave Lister
    Dave Lister Minimodder
    1 Sep 2009
    Triple radiator fits fine on the inside of the aluminium chasis, with the fans at the top above the aluminium chasis pulling air through the radiator. But just like E.E.L. Ambiense before you will lose the top 5 1/4" bay unless you have something half length to go in like a fan controller.
    Anyway the main reason i'm posting after all this time is because i thought i would let everyone know (if anyone ever reads this review again after all this time) that my cosmos s' power switch (touch sensitive) stopped working for no reason, just inside the warranty (thank smeg) at 11 months. Actualy the warranty is 2 years but being within 1 year meant that i could return it to where i bought it instead of having to get in touch with coolermaster.
Tags: Add Tags
