Case Mod - In Progress Cooler master Elite 130 :: simply & easy build
Discussion in 'Project Logs' started by iD2, 24 Sep 2014.
  1. iD2
    iD2 Minimodder
    25 Mar 2012
    Hello , Today i'll show you my new PC build with simple & easy mod and sorry for an images , it didn't have all of step to make it done.
    # Just cut angle aluminum and drill cases with 2 hole for mountting angle aluminum.
    Angle aluminum, i use it for hold PSU.
    PS. Sorry for my English , if i make you confuse please feel free to ask me.
  2. iD2
    iD2 Minimodder
    25 Mar 2012
    # after finished move PSU to bottom then i just finish my black i/o panel. This panel will support me to put CNC component in this cases.
    There connector will support 4 axis stepper motor , 1 e-stop , 3 limit switch.
  3. iD2
    iD2 Minimodder
    25 Mar 2012
    After move PSU to bottom , the heat was more higher than normal so i decide to bought "Samuel 17" & "Corsair SP 120".
  4. iD2
    iD2 Minimodder
    25 Mar 2012
    OK, Let cutting side panel and will glue an acrylic to side panel.
  5. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    Wow that's different. Love the connector panel. Need to see this finished and working should be interesting
  6. iD2
    iD2 Minimodder
    25 Mar 2012
    Thank you.
  7. iD2
    iD2 Minimodder
    25 Mar 2012
    Now i already add white light to it.
  8. iD2
    iD2 Minimodder
    25 Mar 2012
    Acrylic side panel.
  9. flame696
    15 May 2009
    real nice with the lights, which lights did you use as mine seem very dim?
    when are we going to see that back panel connected to something?
  10. iD2
    iD2 Minimodder
    25 Mar 2012
    The lights i used , i bought it from electronic store , it not actually for PC but it cheap and bright.
    For back panel connector , i'll use it for wiring with CNC breakout board and stepper motor controller but i'll done it after i got all of CNC electronic component.
  11. iD2
    iD2 Minimodder
    25 Mar 2012
    After finished connector back panel but look like i'll not finish my CNC soon so i decide to make new back panel by using piece of side panel that i cut it out.
    The new back panel will make my cases more cooler.
  12. flame696
    15 May 2009
    That's so cool love it great work
  13. iD2
    iD2 Minimodder
    25 Mar 2012
    thank you.
  14. iD2
    iD2 Minimodder
    25 Mar 2012
    Just add 80mm fan to back panel
