Cooler Master HAF 932 Front panel USB 3.0 mod
Discussion in 'Modding' started by tbone8, 16 Dec 2023.
  1. tbone8
    tbone8 What's a Dremel?
    16 Dec 2023
    Greetings, I picked up a HAF 932 case a while back for a build I am gonna do over Christmas. I really like the big case but absence of 3.0 USB kinda blows. Racked my brain for a long time trying to figure out how to mod in a 3.0. Picked up one of these JSER Vertical Dual USB 3.0 A Type Female to Motherboard 19Pin 20Pin Box Header Slot Adapter PCBA's from Amazon https://www.amazon.com/dp/B015HKX1ZI/?coliid=I28B05Z51XJFLO&colid=2ZGYBSX8MD3LD ref_=list_c_wl_lv_ov_lig_dp_it&th=1. Wasn't sure till today how I was gonna pull it off but it went better than I thought it would.
    Original board.
    Desoldered the 2.0, note it is a pain to get off with the solder that is on there so flow a bunch of new solder on it to make it easier to remove.
    So, I came up with the idea to solder it upside down on the board. I soldered some scrap wire to lift it up ever with the other plugs.
    Lifts soldered in place.
    I realized I could solder some scrap wire parallel with the solder tabs.
    You have to pre-tin the USB case with solder then hold the wire with tweezers and flow it in.
    All 4 pins soldered in place.
    All soldered in and pretty darn plumb.
    Back side view.
    And son of a gun... Looks like it belongs there, except for being up side down...:clap::jawdrop:
    kim, IanW and Arboreal like this.
  2. LePhuronn
    LePhuronn Minimodder
    6 Oct 2016
