Case Mod - In Progress Cooler Master HAF Stacker MbK
Discussion in 'Project Logs' started by kier, 19 Oct 2013.
  1. kier
    kier -----------------
    1 Mar 2011
    Hi my fellow modders,
    Think you have heard of this new case(s) from Cooler Master: The HAF Stacker
    This combines the HAF and the Stacker series and has a nice and new concept: modular cases
    The case is designed so that can be used to create different configurations. The various housings combined with each other
    This time I will use all 3 parts to build a case that is somewhat larger than normal.
    I will also make use of the fact that there is a great competition going on. Presented by ..... Cooler Master.
    Because they have again the confidence in me to work with this brand new case, I will try to do a Cooler Master casemod competition theme. This will include logos, shapes, little advertising and some updates on this event.
    I will NOT participate this year because of the sponsored case;)
    So if you like to win beautiful prizes
    Come on and participate!!!
    How it all began:
    Sometimes I have a lot of respect for the postal guys. The 3 packages
    Larger then my son
    Unboxing.
    These are the different modular cases:
    Once stacked ... BIG :)
    First some detail shots.
    The 925:
    Inside:
    More parts soon!!!
  2. bulldogjeff
    2 Mar 2010
    I love the idea of that case. I looked at stacking them the way you have when I first spotted them. My only worry would be, being that high and narrow would it be a bit unstable.
  3. kier
    1 Mar 2011
    it's not Jeff, But I will do something in my next log that will keep it stable like no other case before ;)
  4. kier
    1 Mar 2011
    Update!!!
    First some pictures from the two parts I have received also...
    The 915F where the PSU is mounted at the front
    The 915R is for the PSU at the back
    And some pictures outside
    Time to stack all
    915R placed beneath
    915F on top
    Pretty BIG!!!
    Time for some modding I think.
    This time a little different kind of modding. I rotated the case, so it becoming a kind of ghetto blaster.
    I have slightly modified the connection strips so it become all the same on both sides. and removed the unnecessary stuff... maybe placed back later.
    Looks nice all ready
    Placed the original modo tray back under a small angle
    Did some cutouts on both sides
    Removed some steel from the top
    And placed the tray again
    There will be other hardware but this is for measurments.
    Placed some acrylic underneath the motherboard tray for mounting some great products....But more on this later.
    Thanks for your attention ;)
  5. KidMod-Southpaw
    28 Sep 2010
    I definitely like where this is going, especially after seeing the colours in your previous Mbk build. It certainly inspired my current project. :D
  6. CM Nick
    CM Nick Cooler Master Representative
    1 Nov 2013
    Wow, looking good already!
    Looking forward to see what you are going to make of it!
  7. kier
    1 Mar 2011
    Thanks KidMod and Nick :thumb::thumb::thumb:
  8. kier
    1 Mar 2011
    Update!!!
    All the beautiful products have come in the past few weeks for this build. Therefore a major update with everything. There will be 2 updates this weekend, because it's a lot :)
    First, there was a nice package from Cooler Master
    Including pretty amazing fans: The newJetFlow's 120
    Because I'm still not sure which color I'm going to use, I have requested three available colors
    JetFlow 120 white
    Some specs from these great fans:
    • LED Color: Dark (No LED) / Red / Blue / White
    • Dimensions: 120 x 120 x 25 mm / 4.7 x 4.7 x 1 inch
    • Fan Speed: 800-2000 RPM (PWM) ± 10%; w/ silent adapter: 1600/1200 RPM (fixed)
    • Air Flow: 95 CFM ± 10%
    • Air Pressure: 2.72 mmH2O ± 10%
    • Life Expectancy 160,000 hrs
    • Noise Level: 19 dBA (1200 RPM with included silent mode adapter)
    • 28 dBA (1600 RPM with included silent mode adapter)
    • 12-36 dBA (PWM)
    • Bearing Type POM Bearing - CM 4th Gen. bearing (*POM: Polyoxymethelene)
    • Connector: 4-Pin (PWM)
    • Voltage: 12 VDC
    • Current: 0.4A
    • Power Consumption: 4.8W
    Shock-absorbing feet
    Also in red
    And without LED, all black
    Comes with 2 adapters: 1 for 1600 RPM (28 dBA) and 1 for 1200 RPM (19 dBA)
    Power on
    More about the Cooler Master box later ;)
    Also EKWB is helping me with this build, so also a nice EKWB box:
    With lots of lovely products
    First, I have requested two beautiful radiators : De EK-CoolStream RAD XT (480)
    Looks very good with the new Cooler Master JetFlow's
    This set will be placed on both sides of the HAF Stacker, like this:
    For this my good friend Pascal and I made 2 beautiful covers:
    With nice looking bevel edges
    Thanks Pascal van Veen, another piece of art man.
    For this cover I first pasted a layer of white vinyl and then black.
    EKWB radiator behind it with the JetFlow's
    Also, I requested two beautiful reservoirs. The EK-RES X3 400
    With mounting material
    And two extra multiport tops to try some things.
    Which will be placed like this
    Before the update is getting too big, I'll be posting the rest tomorrow. But one more thing ... I received a very nice tool from Mnpctech For my favorite tubing
    De Reamer
    A very nice tool to use internally and externally too deburr and ream edges
    More tomorrow!!!!!
  9. imersa
    imersa Parvum Princess
    9 Apr 2009
    Well :D, them res' fit just great down there
  10. kier
    1 Mar 2011
    Update!!!
    We go on with the EKWB box
    For this build I will use Acetal blocks. First the CPU block.... A EK-Supremacy
    And two beautiful RAM blocks, the EK-RAM Monarch X2
    Will be placed like this
    As you can see I'm going to use the 90 ° and 45 ° black EK-CSQ adapters this time.
    The RAM blocks with adapters:
    The EK-CSQ 90° adapters:
    And the EK-CSQ 45° adapters:
    Also in this build I will use the EK-HD Adapter 10/12mm for the Acrylic tubes
    Female version: EK-HD Adapter Female 10/12mm
    Out of sight, I'll use flex tube with the EK-CSQ Fittingen
    Which then results in a picture like this:
    And yes ... a new motherboard. The ASUS Maximus Formula VI
    Thank you ASUS for providing this beautiful motherboard
    The motherboard :)
    With backplate
    Installed
    As for the GPUs, I'm going to use 2x ASUS GTX780 DCII
    On this two great waterblocks, the EK-FC780 GTX DCII
    Installed onto the GPUs
    With backplate
    Time to install both sides
    Unfortunately don't have enough matte black vinyl for the right cover, so can't finish this one yet.
    I did make a cover for reservoirs with black gloss vinyl.
    Further more made covers ​​for the Mobo tray, sides and the top.
  11. kier
    1 Mar 2011
    Beneath the angled tray of the mobo I have a nice space for SSDs. So I cut a plate, made it black again and mounted the SSDs
    Just don't know yet whether I will place it in an angled or straight position.
    Placed the reservoirs again.
    Cut the top plate cut and made it black also
    + A cover for the mobo tray with the size of the mobo cut out
    Installed it
    Placed the GPUs
    More next week ;)
  12. Primum Agmen
    Primum Agmen New Member
    21 Sep 2012
    I'm not a fan of the case, but I'm loving what you're doing with it.
  13. kier
    1 Mar 2011
    Thanks. Today we continue to add some more colors, and a tricky part ... Tighten the acrylic tubes.
    Update!!!
    Back to the sides. Regarding a wrong size radgrills from a previous build I still had some CNC milled radgrills. perfect and come in very handy.
    Cant say this enough ... Never throw away stuff ;)
    I placed them behind the fanholes and mounted the radiators on it.
    After some thinking regarding the colors, I decided to combine these colors.
    Red and white Cooler Master's JetFlo
    Little bit darker
    Really great fans!! But will have to dim the airflow lol, now they almost blow the sides away :)
    Luckily I received last Friday the black vinyl, so the right side is also finished. Once both sides installed it looks pretty big now
    And turned the fans on again... enjoying the colors
    So did some thinking about the colors for the loops and going to let it flow just like the fans, outside red, inside white.
    In front of the SSDs, the reservoirs... like this:
    Placed the inlets horizonta and parallel to the reservoirs and just like the other tubes.
    Now the challenge. The acrylic tubes that all placed horizontally will need be tighten to something to continue connecting it. So after some brainstorming, I've made a piece of aluminum ​​with holes for tyraps and tighten the 4 tubes from the RAMs. And for the two tubes of the CPU I have cut an acrylic plate and also cut two holes in it.
    Placed a female EKWB HD adapter and a compression fitting.
    Unfortunately out of sight, but looks quite nice like this.
    For the two top connections I have made a similar plate.
    Measuring, drilling, sawing and filing, but I got them all right finally, and as solid as a rock.
    Next week more!!!
  14. Hukkel
    Hukkel James' minion
    20 Dec 2012
    When in doubt...MOAR TUBINGZ!!!
  15. sloth1969
    sloth1969 New Member
    25 May 2012
    Won't the reservoirs block the SSD's when you fill them with your colored coolant. which would be a shame as they look good
  16. kier
    1 Mar 2011
    Update!!!
    Here we go again.... Finally, bought a nice little CPU for this build:
    The i7-4770K
    And I have some beautiful acrylic plates to be made. Doing this by hand is a bit tricky;) so Thanks Pascal for the milling... Great job mate!!!
    So 3 plates on top and a window.
    And some milled strips to try a few ideas
    The front cover is completely acrylic with a milled edge, in order to create a nice window after pasting matte black vinyl for the black edge
    It was a little bit of a challenge to come up with something for the GPU power. For this... the strips.
    Made the two small strips black and then glued it onto the big strip, placed the flat cables first and placed a led strip.
    Aligning and assembled
    Looks nice already
    And have a little change made ​​concerning the colors of the fans ... All white.
    I also got the side plates ready to connect the reservoirs.
    And made them black again, what looks like this once placed.
    Creative with fittings and tubes ...
    And the loop is finished regarding the CPU / mobo section. This all being fed by a D5 pump.
    Time to add some Mayhems pastel red.
    Quite nice, even though it is the back
    1st loop filled
    And the final shot for this update :)
    Made a nice vid about the filling, but will post this later ;)
    Grtz.
  17. Kovoet
    Kovoet New Member
    26 Aug 2009
    You make me sick, damn you for been so damn good at this kier. J/K again awesome work bud.
  18. kier
    1 Mar 2011
    Thanks mate, glad you like it ;)
  19. Hukkel
    20 Dec 2012
    Great job Richard!
    Don't like the coolant colour very much but again like always love the allignment of the tubing.
    Top notch!
  20. Wonky
    Wonky New Member
    7 Jan 2014
    Holy mother of god!
    That's sweet dude!:clap:
    What SSDs are you using and did you paint them or is it their normal colour?
