Hardware Cooler Master MasterCase Pro 5 Review
Discussion in 'Article Discussion' started by Combatus, 18 Aug 2015.
  1. Combatus
    16 Feb 2009
  2. SinxarKnights
    SinxarKnights Minimodder
    21 Jan 2007
    My main gripe with my R5 is how flimsy it is with the fully removable drive cages. Does the partition plate add a lot of strength to reduce flex or is it mostly cosmetic?
    I am always afraid I am going to destroy my motherboard if I pick up my PC the wrong way.
  3. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    I'm surprised you find the R5 flimsy! Though I do think it wasn't quite as well built as the R4.
    Yeah, I'd say the partition here does strengthen the case as well as hiding the PSU etc.
  4. SinxarKnights
    21 Jan 2007
    That is good to hear! Well compared to my Antec 300, the R5 is a wet noodle. But I do think it is because of the drive bays (I have them all removed but one). This is with the side panel off though as that does add a lot of rigidity to the case when secured by the thumbscrews.
    I could be a fringe case. While I don't frequently move my PC around with the side panel off, it does happen. Especially when installing/upgrading hardware or doing routine maintenance.
  5. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Really need to see this case in the flesh as quite like what I see and might be interested.
Tags: Add Tags
