News Cooler Master MasterLiquid ML360 SUB-Zero launched
Discussion in 'Article Discussion' started by bit-tech, 11 Nov 2020.
  1. bit-tech
    bit-tech Supreme Overlord Staff Administrator
    12 Mar 2001
    Read more
  2. cobalt6700
    cobalt6700 Minimodder
    17 Oct 2005
    'Intel Cryo Cooling Technology'.... So will this cooler achieve 123°K? :rollingeyes: (It won't)
  3. Anfield
    Anfield Multimodder
    15 Jan 2010
    I'll just leave this here:
  4. wolfticket
    19 Apr 2008
    I was going to make one of these when I realized the cheap TEC plate I had was almost exactly CPU sized and was suitable for the TDP too.
  5. phuzz
    phuzz This is a title
    28 May 2004
    Ah, we're going back to Peltiers are we? Everything old is new again!
    Although I will admit that a fully warrantee'd all-in-one unit will be a lot easier to fit than the old DIY solutions, although you'll still have all the same drawbacks (more power to run the pelt, which means more heat to remove from your system overall, possible condensation problems, expense)
    So how long until EK or CM release their own phase-change coolers?
Tags: Add Tags
