Case Mod - In Progress Cooler Master Scout 2 Camo Edition
Discussion in 'Project Logs' started by jj_sky5000, 9 Nov 2012.
  1. jj_sky5000
    jj_sky5000 Member
    25 Dec 2009
    Its been a crazy summer & fall , and has been a blast with my family and friends, but back into the garage i go for a few projects. First project is the New Cooler master Scout 2 case, Having a military name and theme on the box i am definitely going a camo theme
    The case has a very sleek design and the Handle on top is great for lan gaming
    I like the window, but since i will be watercooling i will be removing the fan grills and making it bigger
    planning on removing one or both hard drive cages to make room for teh water cooling
    Time to break it all down
    using the scout insignia on the side panel
    Camo paracord just need in a few other builds this will be perfect.
  2. jj_sky5000
    jj_sky5000 Member
    25 Dec 2009
    One would think growing up hunting a fishing i would be able to paint camo that wasnt the case lol . It took me three tries and several stencils before i begin to like the design .
    sanded and Primed
    black then brown
    beige
    a few touches up and it will be finished
    Started cutting out the Guns and skull out of plexi. I ended up redoing the skull
    testing the position
  3. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    well someone should tell CM that loaded guns will shoot much better :) - check that "military clown" on case box...
    oh! nice paintjob here!
  4. krussellusaf
    krussellusaf New Member
    28 Jun 2012
    The paint job turned out great but I think the skull could be improved. I am excited to see more. Makes me want to get to work right now.
  5. jj_sky5000
    jj_sky5000 Member
    25 Dec 2009
    Touching up a few spots
    getting ready to cut a bigger Window out , I did like how this look but going water cooling make a pretty easy descion for me to do it.
    sorry a little blurry
    The paint seems to flow to gether nicely
    Camo, aluminum and Mesh from the case what could i make?
    using the logo from the CM scout 2 box
    no fingers where lost this time ( where my thumb?) jk
    alittle touch of paint suggestion from my friend Haley!!!
    More to come thanks for looking
  6. krussellusaf
    28 Jun 2012
    That Scout 2 logo turned out great. I will be looking for more.
  7. jj_sky5000
    jj_sky5000 Member
    25 Dec 2009
    Thank you !!!
  8. jj_sky5000
    jj_sky5000 Member
    25 Dec 2009
    A little break for the holiday Back to modding, Adding another cut out on the case . using a new blade and u can make some nice tight cuts with this.
    Cm red
    but the finish looks pretty good
    Making room for the 240 rad for the front of the case, The optical drive bays made it too snug, i no longer use optical drives so one less bay wont hurt. so time to bring the dremal out
    Fits now
    Stayed tuned more to come!!
  9. jj_sky5000
    jj_sky5000 Member
    25 Dec 2009
    Next up The camo shroud for the interior!!! Dremal Time
    mesuring it up
    getting ready to make a bend, now wear did i put that bender( all 250 lbs of it)
    It was alot harder to bend than i thought, I need to eat some more and try again
    time to to connect them
    test fit
    sand down my edge
    a little paint
    a little camo
    More to come!!!
  10. Dmlindley
    Dmlindley New Member
    24 Nov 2012
    Love the use of the mesh! very nicely done
  11. jj_sky5000
    jj_sky5000 Member
    25 Dec 2009
    More updates!!!!
    finishing cutting out the window
    Cut out a piece of smoked arcylic
    Time to etch!!!
    Lights out flashlight on( redneck light table (lol)
    I used the etcher on teh ponited ends then bring out the dremal to finish the larger areas
    I will finish the missed spots and clean it all up
    Side window panel done!!!
  12. KrunchR
    KrunchR New Member
    22 Apr 2008
    looks good, dude!
  13. jj_sky5000
    jj_sky5000 Member
    25 Dec 2009
    In order to be stealthy We need to add some silent fans, But clear isnt going to work.
    One of my fav thing about these fans i sthe fan just pops off
    Flat Black
    next up sleeving
    little ass screw drive does have a purpose
    all yea camo sleeving
  14. jj_sky5000
    jj_sky5000 Member
    25 Dec 2009
    A couple of cool things about this pc , its headed to CES in las Vegas in Jan ( super excited). I will have to finish with the components when its gets back, It also entered inot the 2012 coolermaster case mod contest If you like it please follow the link on facebook http://woobox.com/qz4swg/vote/for/138536 also vote for your favorite thank you
    Thanks for watching keep watching after the new year for the New components
  15. WALKYRIE
    WALKYRIE New Member
    29 Aug 2012
    Hi, I dont understand why you black spray the frame of the 120mm fans, there are everywhere online plenty of fans available with black frame
  16. Stem83
    Stem83 Addicted to modding.
    26 Mar 2011
    Cos you use what you already got and change it, thats modding aint it?
    I think it looks good, my opinion, im not overly struck on the guns and skull on the side panel. That aside its a nice mod, good looking camo.
  17. jj_sky5000
    jj_sky5000 Member
    25 Dec 2009
    I have about 15 of those fans and they are pretty slient and free it was easy to use them .
    Thank you Stem83
  18. jj_sky5000
    jj_sky5000 Member
    25 Dec 2009
    Last nite to vote for the 2012 Cooler Master MOD contest. throw some support by casting a vote!!!
    thanks for voting!!!!
  19. jj_sky5000
    jj_sky5000 Member
    25 Dec 2009
    Well The case Made it to vegas and to CES 2013 in one piece,
    Wes from Lanoc took some really nice Pics of the cases In the cooler Master Suite and I thought i would Share
    Hope this will hold you over
    Thanks for looking !!!
  20. xXSebaSXx
    xXSebaSXx Active Member
    21 Aug 2010
    Case? What case? I don't see no case anywhere on them pictures. :)
    Great mod my man... very nice use of mesh and cammo theme.
