Hardware Cooler Master Seidon 120M Review
Discussion in 'Article Discussion' started by Baz, 4 Jan 2013.
  1. Baz
    Baz I work for Corsair
    13 Jan 2005
  2. der_george
    der_george What's a Dremel?
    30 Jun 2009
  3. Gtek
    Gtek Doesn't raise the bar; he IS the bar.
    10 Oct 2009
    Maybe just aluminium fins? I can't imagine CM not being aware of galvanic corrosion :/
  4. David
    7 Apr 2009
    You never heard of inhibitors, fella? :eyebrow:
    It's a safe bet that Coolermaster didn't fill the thing with tap water!
  5. Psyance
    Psyance What's a Dremel?
    6 Dec 2012
    Don't get me wrong, I have not looked into this, however most of the photos that you have linked do not even look like this cooler :eyebrow:
  6. David
    7 Apr 2009
    He's on about galvanic corrosion in general. However, I've yet to hear reports of closed loop manufacturers failing to take it into consideration.
  7. Gtek
    10 Oct 2009
    They probably take it into consideration, but It would be nice to hear from them that they are aware of this potential problem and that they took adequate steps to prevent/ minimize it, like inhibitor additive, passivation, etc.... just for customers peace of mind.
  8. bahgger
    bahgger Minimodder
    13 Apr 2005
    What's with the horrible jpeg compression of the first two ratings photos on the last page?
  9. Joey Propane
    Joey Propane What's a Dremel?
    26 Feb 2011
    Yeah, it goes without saying really. It's a good bet almost all of these AIO units use aluminum rads, considering a standalone 120mm copper/brass radiator is around £25 on it's own.
    Anywho, I have to disagree with the last point in this review:
    It's not really an entry point to watercooling as you don't actually have to do anything outside of what you do with standard air cooling. You mount a cooler to a CPU and a fan to a case, there's no filling, bleeding, cutting hose to length and securing fittings or leak testing... none of the things you need to to take care over when building a properly watercooled PC.
    It's like saying buying an oven is an entry point to learning how to cook restaurant quality food.
  10. David
    7 Apr 2009
    I would say it's closer to "buying an oven is an entry point to learning how to cook".
  11. Zurechial
    Zurechial Elitist
    21 Mar 2007
    Did I miss something here, or was this review written as though 120mm radiators never existed prior to the Seidon 120M?
  12. David
    7 Apr 2009
    Good point, it doesn't look any bigger than the rad on the H50.
    Shirty and YEHBABY like this.
  13. Zurechial
    Zurechial Elitist
    21 Mar 2007
    Or any other 120mm rad that I've ever seen before.
    Maybe I've been hiding under a rock, but since when were radiators designed to fit 'into' the mounting space of a fan, bit-tech? :sigh:
  14. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    Sorry, could've been clearer on that I guess. Point was that as it's a single fan cooler, some cases (e.g. ours) might not be able to fit the rad directly against the rear of the case - we had the same issue with the Intel Thermal Solution water cooler too. It was more just to point this out rather than say anything against the cooler itself, since like you said any other rad would have the same issue.
  15. Zurechial
    Zurechial Elitist
    21 Mar 2007
    That makes more sense, thanks for clarifying!
Tags: Add Tags
