News Cooler Master shares more "Black" details
Discussion in 'Article Discussion' started by CardJoe, 4 Dec 2008.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. Jaguar_Infinity
    Jaguar_Infinity Just some guy
    8 Oct 2003
    Looks nice but doesnt black absorb/retain heat more than any other surface colour?
  3. ChaosDefinesOrder
    ChaosDefinesOrder Vapourmodder
    6 Feb 2008
    yes but bizarrely enough black, and matte black especially, also radiate heat away the best as well!
  4. Nictron
    Nictron Minimodder
    16 Feb 2007
    I can buy a Cooler Master Cosmos Black + HyperZ600 Black CPU Cooler + Cooler Master Black PSU 850 Watt for $800 here in SA. I received the advert yesterday.
  5. scarrmrcc
    scarrmrcc What's a Dremel?
    12 Nov 2007
    black TRANSFERS heat the best. so if you need to cool something down, paint it black, if you need to warm it up, paint it black.
  6. airchie
    airchie What's a Dremel?
    22 Mar 2005
    Locks like one sweet cooler.
    Don't think it'll fit in my laptop though... :D
  7. Cobalt
    Cobalt What's a Dremel?
    24 Feb 2006
    Would be better if the bottom plate wasn't black. Lapped copper for me please :)
  8. Paradigm Shifter
    10 May 2006
    "the best performing CPU cooler on the market"...?
    Wow... that's some claim there. I mean, they've only got three different flavours of the Thermalright Ultra Extreme 120 to beat (normal, black, all copper... if you count the all copper given that it was a limited run)... wonder if they're right, or if it's just the normal marketing hype? My guess is the latter.
  9. _DTM2000_
    _DTM2000_ Minimodder
    9 Feb 2005
    That does look very nice, and I'm sure the matching case will be too. But why all this limited edition 500 units crap. I hate that sort of thing. Just mass produce it so that whoever wants one can get one!
  10. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    If you want to get precise about it, black color only affects radiation emission and absorption. Both get amplified by matt black. Because the cooler is warmer than the surrounding air, emission wins the day and the cooler gets cooled :geek:
  11. Tim S
    Tim S OG
    8 Nov 2001
    I'm thinking it's the latter too since we've only tested the TRUE with a single 120mm fan, whereas the Hyper Z600 only topped out performance charts with TWO fans in push/pull.
  12. mooseguy
    mooseguy Crazy Moose
    17 Oct 2008
    TRUE Black anyone? =D
  13. Nexxo
    23 Oct 2001
    ^^^ Teh sexeah.
  14. mooseguy
    17 Oct 2008
    @Nexxo It's awesome *drool* *wipes drool off nice TRUE black*
  15. cpemma
    cpemma Ecky thump
    27 Nov 2001
    At CPU temperature heads over ambient radiation is negligible compared to forced convection. Colour matters not a jot.
    What does matter is the 2,200RPM fan. Not a low-noise sink, then. :eyebrow:
  16. ParaHelix.org
    ParaHelix.org What's a Dremel?
    19 Jun 2008
    It looks awesome but one of the things I have always worried about with such huge coolers is the weight, it looks like it would punch a hole right through the motherboard, obviously they wouldn’t release them it they were heavy enough to do that but don’t they bend the board at least?
  17. Slyr7.62
    Slyr7.62 «ŚŁÂŶÈŘ»
    14 Dec 2007
    Makes perfect sense.....
    Hot climates=sunshine, which means getting tan. Cold climates usually mean less sunshine, or most skin is covered, so most cold-climate people are light-skinned since they don't always get much sun.
    on-topic. I don't pay over $40 for a HS+F, usually, sorry CM. :p.
    Plus, I'm not having over 800g hanging on my mobo.
  18. docodine
    docodine killed a guy once
    10 Feb 2007
    Looks cool, I guess.
    Why not just paint the original one black, and save yourself some money?
  19. Gremlin
    Gremlin What's a Dremel?
    31 Aug 2008
    you never know maybe their 'enhancements' have improved the single fan efficiency of the cooler, that'd mean chuck a second fan on it and voila better cooling
    but that said i recon bit-tech definitely needs to review this bundle ASAP
  20. Horizon
    Horizon Dremel Worthy
    30 May 2008
    comments about black, that only comes into play when light is involved. So the fact that it is colored black is only cosmetic.
    If you guys look at the bottom-left pic they've blocked off the gaps between the heatsink and cooler.
Tags: Add Tags
