News Cooler Master shows concept case design
Discussion in 'Article Discussion' started by Tim S, 15 Mar 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Koradhil
    Koradhil What's a Dremel?
    9 Nov 2004
    Any more pics from CeBIT? I'd like to see how my casemod looks over there at the Cooler Master stand :D
  3. PA!N
    PA!N What's a Dremel?
    16 Jul 2005
    That case looks pretty *futurish*, I think I like it :hehe:
  4. TomH
    TomH BELTALOWDA!
    28 Nov 2002
    Over-engineered much? I'll wait and see what the retail versions are like, but that doesn't appear to show the same quality we're used to seeing from Coolermaster (eg. ATC201/210, Wavemaster). :sigh:
  5. Hiren
    Hiren mind control Moderator
    15 May 2002
    ^ agree ever since the split with ATC CM cases have been lacking. Although this doesn't look that bad, if they got rid of the hand rails it would look quite funky.
  6. Bluephoenix
    Bluephoenix Spoon? What spoon?
    3 Dec 2006
    hopefully it'll have most of the things that makes the 830 such a wonderful case to use. (removable tray, easy changeover to other configurations)
    the 'gutter' will probably be ripped out by most, and the drive cages are a bit of a disappointment to those of us that prefer to use removable 5.25" modules. the bottom mounted PSU is nice to see, hopefully they can do like the Antec P180 and put a vibration damping cage around it.
    Personally I think that the use of only 5.25" slots with a moveable cage was the best thing to happen to the full-tower cases.
  7. Guest-23315
    Guest-23315 Guest
    Where o' where is our original Wavemaster with 120mm fans Coolermaster??
    That would deffo be case for everyone.
  8. Koradhil
    9 Nov 2004
    The Mystique has 120mm fans also.. I got a yellow wavemaster right here and I got a Mystique 631 as well :)
  9. Skill3d
    Skill3d Minimodder
    29 Sep 2005
    I like their quality, but personally I don't like the design...
  10. Crazyglue
    Crazyglue What's a Dremel?
    27 Nov 2005
    wow that case looks awful, it way too complex, and the side handles look a bit funny... ah well, guess not everything is perfect
  11. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
    Me too
    This case looks interesting, I like the handles but not the door (it looks nice but I don't like doors on cases) or window (don't have a window above my car's engine, don't need a window above my CPU).
  12. ou7blaze
    ou7blaze sensational.
    5 May 2003
    I like the case it looks quite good except for those rather funky looking handlebars :/
  13. Cobalt
    Cobalt What's a Dremel?
    24 Feb 2006
    Looks like the perfect base for a mod I had in mind (saves me a lot of acrylic cutting) but most of it would disappear, including those handles. Its not a bad idea to put them on the base but why on top as well?
  14. HandMadeAndroid
    HandMadeAndroid That's handy.
    18 Feb 2005
    Mutton dressed as lamb
  15. ralph.pickering
    ralph.pickering What's a Dremel?
    6 Apr 2005
    Looks a bit like a mini-van with those roof rack bars. I wonder if Thule will bring out a compatible luggage box or bike carrier.
  16. Tyinsar
    26 Jul 2006
    maybe to carry it with? - they are handles :D
    :hehe: sounds like something the user "nature" would say (though I'm usually more perplexed by his posts) (which used to be followed by a request for Bindi to change his avatar) :rolleyes:
  17. Woodstock
    Woodstock So Say We All
    10 Sep 2006
    had to laugh at that reply. dont think ill be lining up to purchase one anytime soon (or later for that matter)
  18. Tyinsar
    26 Jul 2006
    Thanks, I'm here until Friday :D . Try the veal, (or should that be lamb? :confused: )
  19. Paradigm Shifter
    10 May 2006
    Looks like they've borrowed some ideas from the Mac Pro case... (the HDD caddy/bay efforts...)
    If it's well built, it could be a good case. If they use too much plastic, however... it's gonna be flimsy as hell and more of a liability than an asset. (Hopefully something like the two-material three-ply Antec used for the P180?)
    Not really sure I like those rails on the top and bottom, though...
  20. Iago
    Iago What's a Dremel?
    4 Oct 2005
    I'm officially sick of window panels. The case looks fine, but the sooner the side windows goes the way of the dodo, the better.
Tags: Add Tags
