Modding Cooler Master V8 Mod
Discussion in 'Modding' started by steelkane, 16 Dec 2008.
  1. steelkane
    steelkane It's Not Just A Box
    11 May 2008
    Today I'll be modding a Cooler Master V8 with a higher CFM fan & white Leds instead of the Red. First I ordered some part from FrozenCPU
    1/4W Metal Film Resistor 10-Pack - 470ohm (12 V DC)
    5mm White LED
    Black 1/8" Nylon Cable Sleeve
    Scythe SY-1225SL12SH SlipStream 120mm Fan 1900RPM 110CFM 37dBA
    Next I started to make a led power cable, by soldering the 470ohm Film Resistor on the red wire on a 3 pin connector.
    The completed led power cable
    Next I drill a hole in the top of the fan to allow the led to insert.
    The led power cable attached & ziptied on the bottom.
    I did both sides the same then put the new fan in & put the V8 cap back on.
    That's it for today,, Next I will install it on my Stealth 2 Duo Rig, I Hope for it to cool better because of the higher CFM fan, the white leds will match my setup.
  2. Tec_
    Tec_ What's a Dremel?
    26 Feb 2008
    good job i like it!
  3. steelkane
    11 May 2008
    thanks, When I shut it down to install the V8, core temp read 98F at 3.1GHZ, V8 installed Screen Shot
    I was hoping to see better temps with it,, they did improve, Here's some pictures of it installed.
  4. Lucas
    Lucas What's a Dremel?
    14 Dec 2008
    That's nice looking! How much do you buy those material for modding?
  5. Antihista
    Antihista What's a Dremel?
    18 Mar 2010
    what theme are you using?
