Ok, i want to change my plexi case and i was looking at the cooler master stacker. Will be getting it in a month or so. Not the new one, i'm not that rich but the old one is a monster and that's what i'm looking for, lots of room, even for a second PSU. My question is does anyone have any bad point against that case, i dont want any surprise Here's a pic (i'll get the all black one) Thanx guys
Having an open fronted grill, the stackers not the quietest case, but its just so flexible, and you can run 120mm fans on low and use quiet coolers to cut out any component noise from within the case.
I have the one that only mounts a PSU in the bottom. and that is my complaint. at the time i ordered i thought i was getting the dual pSU verssion. Other than that i would just say dont use the mounting clips, just screw your dives in, mine were a little too wobboly for my tastes. otherwise its a fantastic case. the best way to clean it is with a vac, to get the dust.
I have a custom one. Awesome case, just awesome. Only niggle is to mount a 120mm fan in the front, you have to use drive bays for mounting.
I really like mine. Tonnes of room to work in, which is a godsend for anyone who's spend years working in cramped case. It'll support a 2TB RAID 5, when I eventually get the money together for it, and it remains fairly cool, if rather noisy. I'm yet to try it with silent panaflow's though, so its possible it can be significantly quietened.
noise isn't really my problem, i have one of the noisiest case ever, at one time i had 15 fans in it. Cant wait
I dont have it but it look pretty good. I have also hear good things about it. Go for it and dont worrie about the noise, who cares, I dont. Especially when your music overpowers it anyways
