Scratch Build – In Progress [Cooler Mod] Abstract by AnG3L - Vote & Support a friend!
Discussion in 'Project Logs' started by AnG3L, 31 Oct 2012.
  1. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    I would like to welcome you to my this years entry which is going to be a scratch cooler mod based on Coolermasters V6GT Cpu cooler!
    I am going to improvise once again so expect constant changes and a theme based on abstract art. So lets start!
    Here I fully disassembled the cooler. The only part I am going to use is the heatsink and the fans.
    The main materials that I am going to use with my creation is aluminum and acrylic. Here I use some aluminum angles for the main part which
    is going to connect the heatsink with the custom body. First I created two same pieces for each side but afterward I changed my mind and used only one as
    I changed my original plans!
    I am using the most simple tools for that creation as I wanted to enjoy this instead of using laser or cnc which I have easy access to them. Back to basics for more modding joy and to showoff my skills!!!
    Testing the holes for the main screws. 100 % success! :)
    Adding the thread inserts for the fan screws.
    For the top part I used a 5mm clear acrylic piece I had spare lying around which it was already bend too! Also removed a piece from the aluminum part
    for maximum airflow.
    Next I created a piece out of 2mm aluminum for my custom fan holder. Took me a while to cut and file it due to the use of simple tools!
    Here is the creation of my custom fan shroud. I used a 1mm aluminum sheet which I bended on a 120mm surface by using a plastic hammer.
    Mark it in order to cut 2 same pieces.
    I draw a 120 mm circle in order to make sure everything is bend properly. I connected the 2 pieces with 5mm X 2cm acrylic which I filed into the desired shape.
    Next part is the piece which is going to hold the shroud on the main top part. Simple tools and files were used so it took me a while!
    I used an aluminum grey spray paint I found accidentally in the DIY store which turned out to be so strong imitating almost powder coating!
    I removed the frame from the fans as I am going to make custom ones. The fan stickers are the same I used for the Future Schlock Project I did in the past.
    More parts from acrylic were created for the top part and more will follow!! I also polished the shroud holder instead of painting it!
    Thats all for now guys, thanks for watching my work, till next update, peace!
    Omoobhs likes this.
  2. AnG3L
    19 Mar 2009
    I will continue with the final update and pictures!
    I have added some di-noc carbon fiber for an extra touch (haters dont bother cause I proved my self already) and also added
    a red led which can be plugged in HDD Power or activity! Enjoy!
    Waynio likes this.
  3. KidMod-Southpaw
    28 Sep 2010
    Looks astounding! :jawdrop:
  4. Razarach
    Razarach Minimodder
    28 Jan 2009
    Perfect. Nice work ;)
  5. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    This thing looks stunning... Love the somewhat organic feeling to it, ang3l style. I generally dislike the use of carbon fiber, but this one looks sooo god. And the fan in the back, hanging from above, mmmmm... Very well done, as usual :rock:
  6. jrs77
    jrs77 Modder
    17 Feb 2006
    Very nice, allthough it would be a total waste in any of my cases during the last 15 years due to the lack of a window ^^
  7. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Just wow! :eek:
  8. subby
    subby Me...just like you...only better
    5 May 2009
    Looks amazing, well done :)
  9. Mechh69
    Mechh69 I think we can make that fit
    16 Sep 2009
    Beautiful job first of all, second I liked the fact that you used simple hand tools to create your project and did a wonderful job at it. It looks very professional and honestly if you would have not said you used simple tools I would have never guessed it was hand made. I'm working on a current project now but I'm not sure that I am going to post a log as I have log envy from watching you guys with your works of art!.
  10. Attila
    Attila still thinking....
    22 Feb 2008
    Good to see you back mate. :thumb: Nice work and a nice little mod. Good luck in the comp. :)
  11. KithKhan
    KithKhan A dremel is all you need.
    24 Feb 2012
    That's one of the coolest mods ever!
  12. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    GOD I've missed you and your genius modding! :thumb:
  13. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    is there word EPICEST in english?
  14. Waynio
    Waynio Relaxing
    20 Aug 2009
    +1 Absofeckinglutely :D:hehe:
    Woo hoooo, it's soooo good to see you modding again Alex, my eyes lit up & I grinned like a Cheshire cat when I seen a new project with your name attached. :D:rock::clap:
    Mighty fine bit of modding there & trade markably original as always, short but awesome mini project, hope we see more from you sometime soon, you've definitely been missed. :hip::dremel:
    Am I ever glad coolermaster decided to do an alternative compo & you couldn't resist. :D:clap:
  15. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    Very nice :)
  16. phinix
    phinix RIP Waynio...
    28 Apr 2006
    Sweet, man! I love it. See, you always do these kind of "organic" shapes - it's never just a rectangular, angled shapes. You always add this artistic touch to those pieces to make it all together unique and original.
    I really like acrylic pieces and I can bet that top bit was hard to polish to this result!
  17. AnG3L
    19 Mar 2009
    Thanks Kid nice to see you again!
    Thanks mate! :)
    Thanks bro, carbon was used last minute to give it a little extra touch, guess some people like it and some dont. Also one guy attacked me on FB lol crazy things going on! :p
    Dremel - acrylic = done! :) Thanks mate!
    Thanks!! :)
    Thanks man! :)
    Simple tools and things I had laying around due to lack of money but I managed to finished it by actually buying only a primer! ;) Thanks bro! :)
    Thanks Attila my friend always nice and honored to hear from you!! :D
    Wow thanks mate! :thumb:
    I ve missed you too you bald crazy bas!#$% :p Thanks brah! :rock:
    We will make this an official word! :) Thanks man! :thumb:
    If there was an award for commenting it will actually had your name bro something like "Wayne's Awards" !! Thanks brother I always appreciate your presence and comments! Dont think that I will be modding any time soon, this was just something to enjoy and fill my empty time!! :)
    Thanks!! :D
  18. AnG3L
    19 Mar 2009
    Nice to hear from you mate!! Yeah you are right organic shapes, crazy ideas and polishing was a little harsh even though I had more more difficult projects in the past (Synthetica!) Thanks for being here and commenting bro!! :)
  19. dmcgrath
    dmcgrath Master of Pancakes
    14 Aug 2011
    Alex, thanks for opening up that box and showing us where you keep your amazing brain!
    Can a cooler be nominated for MOTM? I think you deserve it.
  20. bulldogjeff
    2 Mar 2010
    Alex, you have taken a part not many people bother modding and turned it in to a master piece, loooks absolutely brilliant mate...top moding
