Cooling coolercases .co.uk tdx
Discussion in 'Hardware' started by Pie_uk, 8 Apr 2005.
  1. Pie_uk
    Pie_uk British beef, in Britain
    6 Apr 2005
    http://img53.exs.cx/my.php?loc=img53&image=just20gr.jpg ok the kit that is 175£ comes with the tdx block (tdx kit) and contains 4 mounting holes for the board but just as i was about to place the order i found the tdx a64 block but this has just two mounting bracket things check that link above, so basically i ent moving till i no for sure , ps iv tried workin it out but cant , i have a soc 939 abit av8-3rd eye please help me , or dosnt it matter check this pic,[​IMG] i have put the red arrows indicating the 4 holes on the out side and the blue as the 2 holes (which i belive hold the sort of plastic sub frame of which the hsf sits in)
  2. Pie_uk
    6 Apr 2005
    if no one knows ill take the board out tomoz to check.
  3. Kameleon
    Kameleon is watching you...
    29 Apr 2003
    The blue arrows are the ones that you'll be mounting the waterblock with. No idea what those things marked by the red arrows are. However, the kit that I think you're talking about (this one, no?) has a different block which has mounts included for all sorts of sockets.
  4. Pie_uk
    6 Apr 2005
    so basically i need the block in the link i gave? the kit i want is this one but the block is differnet to the one in the link [​IMG] [​IMG]
  5. Pie_uk
    6 Apr 2005
    as you can see the kit contains the block with 4 mounting holes , but the a64 block contains 2 holes , this is were im getting confused , :wallbash:
  6. alastor
    alastor Minimodder
    6 Sep 2004
    Just a little furthur down on the TDX Hi-Flow Bundle page is this:
    So I would imagine it would come with the 2 hole A64 block. :D
    I'm sure Paul will come and clear this up eventually.
  7. Pie_uk
    6 Apr 2005
    yer wkd , its doind my head in lol speacialy as my board has those 4 holes then the 2 holes aswell, so basically i put please containd the a64 block (in the special notes bit)
    paul ..... help lol
  8. b1g-d0g
    b1g-d0g Modder
    30 Sep 2001
    If you ask for a amd 64 block you will get one dont worry :)
  9. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Add it to your basket and it'll probably ask what type of TDX you want (in this case A64) If you're still confused drop Paul a mail and i'm sure he'll help you out :D
  10. Kameleon
    29 Apr 2003
    In fact I would imagine it would by standard come with the 4-hole Socket A block (as pictured)...so good thing you specified ;)
  11. alastor
    alastor Minimodder
    6 Sep 2004
    Didnt think of that :blush:
  12. Pie_uk
    6 Apr 2005
    ok i mite email him, cant i just private mail him? yer i would imagen if i asked for the a64 tdx cpu block id get it lol
  13. Nexxo
    23 Oct 2001
    The kit which you want to buy specifies:
    When you order the kit, you will find a "Special Notes" section to fill out on the Buy page. Simply state in there that you want an Athlon 64 block. You will then be sent the correct kit.
    If you leave that section blank, you are sent a Socket A block per default.
    If you want to e-mail Paul, please do so via the shop e-mail address.
