News Coolermaster AERO 7+ HSF at GruntvillE
Discussion in 'Article Discussion' started by GreatOldOne, 15 Jul 2003.
  1. GreatOldOne
    GreatOldOne Wannabe Martian
    29 Jan 2002
    GruntvillE takes a look at Coolermasters new high-performance addition to their AERO line of heatsinks, the AERO 7+:
    "At first look, the heat sink looks like your typical copper base with skived fins, but one quickly notices the odd-shaped clear/aqua colored fan that sits atop. It is this unusual looking fan that sets the Aero 7+ apart from other cooling setups. Unlike the common axial type fans you'll find with most heat sinks, the Aero 7+ uses what's referred to as a blower fan, similar in design to what you'd find inside the housing of a turbo charger.
    Now you may be asking yourself "How is it really better than a normal fan?", after all, a fan of any kind still just moves air right? Well, to explain it, let's first take a look at airflow movements created by each type of fan."
    Full review here, and for a second opinion don't forget to check out Cheese's review
Tags: Add Tags
