Hi, so i bought this case and i want to take the bottom of the hdd cage out. But i can't seem to fit any screw driver in. I've read that it definitly comes out and you just need to remove the 8 screws but i can't seem to do it. Should i just drill them out? Anyone else removed their cage before? Advice appreciated. Thanks
There's 4 screws at the bottom of the case, you have to take them off from the outside of the case. Remove the dust filter fabric if it's blocking access to them, I can't remember exactly.
Any cross-blade screw driver of a normal size will work fine, they are very, very easily installed/uninstalled.
