Modding Coolermaster Cosmos Mod question???
Discussion in 'Modding' started by sweets, 11 Oct 2007.
  1. sweets
    sweets What's a Dremel?
    8 Sep 2007
    Hey guys and gals,
    Trying to remove the plastic quick release tabs for the optical drives so I can sand and paint the interior of the chassis. Can anyone give me quick three step procedure for doing so? I have tried to slide them backward, but to no success.
    Thanks in advance.
    Working on a nice little Cosmos mod that I think I'm gonna start a project log on. I'll see what happens.:dremel:
  2. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    Be better to ask Coolmeister, I'd assume - he's currently modding a Cosmos also.
  3. sweets
    8 Sep 2007
    Yeah, I left a message in his project log, but I thought perhaps someone over here might have a quick answer as well.
    Thanks. :)
  4. scooby
    scooby Minimodder
    3 Mar 2004
    Wish I had the case so I could tell you but I don't. What color are you going to paint the interor?
  5. sweets
    8 Sep 2007
    Thinking about black but I might go for a dark steel grey. Basically gonna do the entire steel chassis. Sanded almost everything down with 220 grit, but I need to get the quick release tabs off yet. :wallbash:
