Case Mod - In Progress Coolermaster Cosmos S
Discussion in 'Project Logs' started by Iraklis Gkolios, 27 Aug 2013.
  1. Iraklis Gkolios
    Iraklis Gkolios Member
    21 Aug 2013
    Hello Bit-Tech
    This project log has some history behind. First of all i am gonna mod the same case i used for my first mod . Its an old Coolermaster Cosmos S case that i tried to mod around late 2010 early 2011. Since then i think that my skills have become a bit sharper and i want to give that case a second chance before it meet its maker.
    My plan for this mod will be a small scale dont to the case it self. I am planning to recude the length of the case around 10 cm. That means that ill have to cut also the top and botton handles and the side panels also. I am gonna use top mounted motherboard tray, bottom mounted PSU, Triple radiator on the front side plus more radiators around the case. Also i am gonna make the same window opening mechanism as the Cosmos II, but the dream goal is to achieve a way to make the panels open in a lamborghini way. For the color scheme of the build i will use mostly black matte and black matte vinyl and i only have to choose a vivid color for the details.
    Full build log here
    My other build log
    Hope you enjoy
    Cheers
    Iraklis
  2. Iraklis Gkolios
    21 Aug 2013
    New update 31/8 Some metalwork !
    Here is the metal work i did today.
    I am also planning to make this case a Cosmos II since i figured out that i can buy with around 150 euros the whole exterior of cosmos II and save around 200 euros in the process !
    Cheers
    Iraklis
  3. Concept73
    Concept73 Wannabe modder.
    30 Aug 2013
    looking good so far!
