Coolermaster Hyper48 PWM Fan
Discussion in 'Tech Support' started by [DE]FreD_S, 25 Apr 2006.
  1. [DE]FreD_S
    [DE]FreD_S Certified Specialist of Awesomeness
    6 Jan 2002
    Hi!
    Long time no write... hehe... okay, I got myself some new toys and one of them is the H/F mentioned in the title. I have the Asus A8N-SLI and this mobo doesn't have a PWM port... so the fan is constantly running at lowest speed. How can I increase the speed of the fan? It can go up to 3200 RPM and is currently running at 550... I'd like it to be around 1500 - 2000 RPM...
    Cheers
    Fred
  2. hitman012
    hitman012 Minimodder
    6 May 2005
    The A8N-SLI motherboards have full fan control for the chassis and CPU fan headers. Under the Power menu, go to the hardware monitor and either disable Q-Fan Controller or set the CPU Target Temperature to something lower.
  3. keith_j_snyder2
    keith_j_snyder2 What's a Dremel?
    22 Apr 2006
    Hey Got the same Fan!!! & i also seen the same thing.It never exceed this speed i have MSI RS480M2 mobo. but is it giving any troble to u? I mean any malfunctioning?
