has anyone got one of these,if so what CPU are you using. i'm thinking of buying one but i want to know if it can cool a XP2600.
i got an aero7+ which is more or less exactly the same but has a different look (they both perform the same). Im currently cooling (at medium fan speed, pretty much silent) a 1800+ @ ~2600+. idle 42* load about 48-51*C. Although a real 2600+ will run MUCH cooler. Non-overclocked i get 32*c idle and 37*c load i know someone with a JET7 and a 2600+ barton and they run it max speed and get 30*c idle and 35*c load
Have a look at some reviews for the Aero 7 Lite - seems to be quite a good performer for the price, and its rated up to 3200+ at reasonable temps. Most have said that because its a copper-cored aluminium sink, its a better cooler than the more expensive Coolermaster ones. U should be able to find it for around £15 at most UK stores. Dont worry about what temps u might get - as long as they stay under or around 50°C load u will be fine.
