Cooling Cooling a room
Discussion in 'Hardware' started by Timdog, 20 Sep 2003.
  1. Timdog
    Timdog What's a Dremel?
    7 Sep 2003
    I want to see if I can bring down the temperature in my room a little bit. I have central AC in the house. It is set at 72 F and it works, but my room still gets warm because of the computers especially after I have been gaming for a few hours. I have two vents that bring in cool air and one that takes the hot air out. I also have two box fans and I was wondering if I could use these to cool the room down more?
    If the mods feel a need to move this to another forum if it is not meant for here please do it. :clap:
  2. jafb2000
    jafb2000 What's a Dremel?
    3 Jun 2003
    With A/C, there are booster inline ducts made for such purposes.
    However, there are some simple things you can do:
    o Power off CRT monitors when not in use
    ---- eg, don't run overnight
    o Deal with solar gain
    ---- more dependent on which way your window faces
    ---- however a simple roller window blind can help considerably
    o You have 2 cool-air intake & 1 hot-air exhaust
    ---- depending on design it could be the exhaust that is restrictive
    However, before you go sticking fans on your exhaust intake...
    o They need to be higher cfm than that already moving thro it
    o PC fans are terrible at static pressure - ie, moving air thro ducts
    Thus PC fans are not a particularly good solution here.
    That is unless your hot-air duct out is 6" to free air (I doubt it).
    If machines are not used intensely, it can be worth using a
    power-saving program - for laptops there is "Rain". I can't
    recall if a similar program exists for desktop CPUs - suspect
    it does since CPU-throttling is not just mobile specific.
    Hotter rooms reduce your cooling system effectiveness thro
    reducing the temperature delta between heatsinks & air-temp.
    So reducing the room temperature has benefits to equipment.
    PC fans are not the same as A/C (duct) fans however :)
    A low-noise PC fan produces 0.1-0.2" of water-pressure, a good
    duct fan produces orders of magnitude greater pressures.
