Cooling Cooling a Ryzen 5900X and Crappy Motherboard (Was: Cooling a Ryzen 9 9950X... on air?)
Discussion in 'Hardware' started by Gareth Halfacree, 3 Apr 2025.
  1. sandys
    sandys Multimodder
    26 Mar 2006
    On the pump noise front, I was just thinking, my PC and NAS are within 1 metre of me with pumps running, don't hear it, noise is the reason I am all SSD in the NAS and use low speed fan cooling on my rads etc, also the reason my water can go to high temps as I don't allow it to max out the fans and have massive ramp up once it goes past a trip point, loop is handling ~600w when gaming, same rads and hardware have handled 1kw in the past, water is so good, obviously fans here did have to work harder but again noise was tolerable because it was consistent DIN, though it is fair to say when I game I am on headphones, PC can ramp up to whatever it likes then, biggest issues is me melting due to heat being kicked out :D
    I can tolerate a bit of noise, but it is all about consistency and frequency, it has to be low, noisiest, most annoying thing in my office is my keyboard and mouse .... I've removed chipset fans etc because of their noise, it's something I can't tolerate when working, I've nothing special, some laing DDC pump res combo, it's very quiet. Pump does ramp up with fans when gaming but generally loading CPU is so low wattage in comparison to a GPU I can't think of when it has ramped up outside of games, just one low fan noise.
    Tried a prime95 just to see what the 5950 OC'd actually does upcapped and indeed the fans and pump to kick up but the CPU is chugging down 260W, when it is doing this my Pump is actually audible, so I'll take that back but that is probably as it has gone from 900rpm to 4500rpm, there is probably a sweetspot in there and in fact now I have stopped the stress test with pump at 3200 you can't hear it just case fans, so I could cap it there, still plenty of flow.
    wyx087 likes this.
  2. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
    I'm super lazy. Bigass Noctua of choice + square of PTM 7950 = Several years of maintenance free adequate performance. Just clean the dust filters now and again.
    I'm not quite brave enough to run my home PC on graphite thermal pads like I do all the work laptops...
    Byron C, yuusou, Pete J and 2 others like this.
  3. Pete J
    Pete J Employed scum
    28 Sep 2009
    You and I can be friends.
  4. Gareth Halfacree
    4 Dec 2007
    Decided to see if I can get a few more years out of what I've got: already upgraded to 64GB of RAM (which, given it's a two-slot motherboard, is about as far as I can take it) and picked up a 5900X on the Marketplace - same TDP as my 2700X, so I'm hoping the Wraith Whateveritis will handle it (and if not, I'll have to pick up a new cooler too), but 12C24T instead of 8C16T (instant 50% speed boost for my highly-parallel workloads, even before you factor in the improvements between Zen+ and Zen 3) and 4.8GHz boost instead of 4.3GHz (again, assuming the cooler is up to the job.)
    wyx087 likes this.
  5. sandys
    sandys Multimodder
    26 Mar 2006
    Boring, booo, not even a 5950 :D , still its a nice cheap option, there's a pretty good x570 gigabyte motherboard on marketplace with 4 slots you could make an offer on to get that RAM up to 128. I think that its the same board I am running.
    The_Crapman and Gareth Halfacree like this.
  6. wyx087
    wyx087 Multimodder
    15 Aug 2007
    Remember to check BIOS update to ensure it works when dropping in the 5900x.
    Gareth Halfacree likes this.
  7. Gareth Halfacree
    4 Dec 2007
    Yeah, I'm on the latest BIOS (which is still pretty old,) which matches what Asus says I need for a 5000-series. Fingers crossed!
    wyx087 and Arboreal like this.
  8. sandys
    sandys Multimodder
    26 Mar 2006
    Thought I'd look into reducing that pump noise at load, fiddled nothing changed, then I remembered what that noise actually is, my UPS :eek: , I had a UPS failure, so my system is running off a little back up UPS, I forgot, its not that happy with the big PC on it and is running near capacity so its fans come on, probably if I added another 100w load its alarms would have went off.
    Funny thing about fitting the replacement UPS is you have to actually wire it in for it to be any good rather than just stacking it in top of the other one :duh: :D
  9. Gareth Halfacree
    4 Dec 2007
    New CPU get! Installed! Had a few crashes before I just gave up and reset the BIOS to defaults!
    It wouldn't see the temperature sensors at first, which was annoying, but that's a software thing: I'm on Ubuntu 20.04 'cos I can't be faffed upgrading, and thus Linux 5.4; 3000-series-up AMD stuff was added in 5.10. Stuck the HWE kernel in there, now I'm on 5.15... which is still ancient, but new enough.
    Fun thing: now that I'm on a newer Ryzen, the DOCP profile in the BIOS has the RAM running at its rated 3,600MHz. Yay!
    Still need to stress-test the thing, make sure it's stable, but it's looking good. The new cooler (Thermalright Peerless Assassin 120 SE) is a big improvement: idling slightly higher, maybe, but under all-core load - 12C24T, 4.4GHz dipping to 4.3GHz every so often - it's sitting at 72°C absolute maximum, mostly a degree or two lower, and the fans are silent ('cos I set a curve that says "don't get angry until at least 80°C," which was a good guess!) The old 2700X under the Wraith Thingy used to hit 86°C easy with the fan on full blast (though not full full blast, the L-H switch was on L) and was way noisier. Definitely pleased I picked that up.
    EDIT:
    Need to use it for Actual Work now, but had it running a 24-thread sysbench CPU prime number workout while also testing the RAM: no crashes, no errors.
    Code:
    memtester version 4.3.0 (64-bit)
    Copyright (C) 2001-2012 Charles Cazabon.
    Licensed under the GNU General Public License version 2 (only).
    pagesize is 4096
    pagesizemask is 0xfffffffffffff000
    want 57000MB (59768832000 bytes)
    got  57000MB (59768832000 bytes), trying mlock ...locked.
    Loop 1:
      Stuck Address       : ok
      Random Value        : ok
      Compare XOR         : ok
      Compare SUB         : ok
      Compare MUL         : ok
      Compare DIV         : ok
      Compare OR          : ok
      Compare AND         : ok
      Sequential Increment: ok
      Solid Bits          : ok
      Block Sequential    : ok
      Checkerboard        : ok
      Bit Spread          : ok
      Bit Flip            : ok
      Walking Ones        : ok
      Walking Zeroes      : ok
      8-bit Writes        : ok
      16-bit Writes       : ok
    wyx087 and Pete J like this.
  10. Gareth Halfacree
    4 Dec 2007
    Oh, I forgot: pictures!
    (Yes, I remembered to plug the GPU back in before I put the side on!)
    The only thing I'm not happy about: the front fan is raised up a bit (as you can see) 'cos it sits right on top of the RAM, which means the RAM won't be breathing quite as freely as before. Probably not a problem, but it's a shame heatsinks aren't as effective in a pull configuration 'cos then I'd put the fans on the back of each stack instead of the front!
    Oh, and it looks like the 140 would have been fine - there's bags of room, no idea what Fractal's on about when it says there's a 160mm HSF height limit.
    The_Crapman and wyx087 like this.
  11. sandys
    sandys Multimodder
    26 Mar 2006
    :idea: now go into BIOS turn on PBO and set a -20 curve (-10 if you want to be conservative) for more power it pretty much comes for free :D
    Pete J likes this.
  12. Gareth Halfacree
    4 Dec 2007
    Totally off-topic, but while everything seems completely stable I'm having some weird USB issues.
    I don't turn the desktop off; I suspend to RAM. Which works fine, hit a key on the keyboard in the morning, it wakes up, lock screen appears after a couple of seconds, I enter my password, boom.
    Except now. Now, I hit a key on the keyboard, it wakes up, lock screen appears after a couple of seconds... but the USB peripherals are dead. System is unresponsive to keyboard or trackball, keyboard backlight is off, trackball doesn't make the clicky-clicky-clicky (which, fun fact, comes out of a speaker) when I use the scroll function.
    First time it happened I unplugged and replugged the USB hub. There was a delay, then everything sprung into life. Weird, but whatever.
    It just did it again. This time I left it for a bit: after a few seconds the keyboard backlight came on and the trackball made a little "click", and I could move the cursor... but pressing a key on the keyboard or clicking didn't dismiss the lockscreen and bring up the password entry screen, it just sat there. After a few more seconds, I was able to dismiss the lockscreen and log in. After that, everything's fine. All USB peripherals detected and working, I can type, no problems.
    Weird, and annoying.
    Code:
    [31459.200226] hub 5-1:1.0: hub_ext_port_status failed (err = -71)
    [31459.200593] usb 5-1-port4: cannot disable (err = -71)
    [31459.201341] usb 5-1-port1: cannot reset (err = -71)
    [31459.201716] usb 5-1-port1: cannot reset (err = -71)
    [31459.202091] usb 5-1-port1: cannot reset (err = -71)
    [31459.202466] usb 5-1-port1: cannot reset (err = -71)
    [31459.202841] usb 5-1-port1: cannot reset (err = -71)
    [31459.202850] usb 5-1-port1: Cannot enable. Maybe the USB cable is bad?
    [31459.203216] usb 5-1-port1: cannot disable (err = -71)
    [31459.203591] usb 5-1-port1: cannot reset (err = -71)
    [31459.203966] usb 5-1-port1: cannot reset (err = -71)
    [31459.204341] usb 5-1-port1: cannot reset (err = -71)
    [31459.204705] usb 5-1-port1: cannot reset (err = -71)
    [31459.205079] usb 5-1-port1: cannot reset (err = -71)
    [31459.205081] usb 5-1-port1: Cannot enable. Maybe the USB cable is bad?
    [31459.205455] usb 5-1-port1: cannot disable (err = -71)
    [31459.205829] usb 5-1-port1: cannot reset (err = -71)
    [31459.206204] usb 5-1-port1: cannot reset (err = -71)
    [31459.206579] usb 5-1-port1: cannot reset (err = -71)
    [31459.206954] usb 5-1-port1: cannot reset (err = -71)
    [31459.207329] usb 5-1-port1: cannot reset (err = -71)
    [31459.207331] usb 5-1-port1: Cannot enable. Maybe the USB cable is bad?
    [31459.207704] usb 5-1-port1: cannot disable (err = -71)
    [31459.208079] usb 5-1-port1: cannot reset (err = -71)
    [31459.208455] usb 5-1-port1: cannot reset (err = -71)
    [31459.208829] usb 5-1-port1: cannot reset (err = -71)
    [31459.209204] usb 5-1-port1: cannot reset (err = -71)
    [31459.209579] usb 5-1-port1: cannot reset (err = -71)
    [31459.209581] usb 5-1-port1: Cannot enable. Maybe the USB cable is bad?
    [31459.209954] usb 5-1-port1: cannot disable (err = -71)
    [31459.210329] usb 5-1-port1: cannot disable (err = -71)
    [31459.210704] usb 5-1-port1: cannot disable (err = -71)
    [31459.303305] usb 1-8: reset high-speed USB device number 7 using xhci_hcd
    [31459.303740] hub 5-1.3:1.0: hub_ext_port_status failed (err = -71)
    [31459.304472] hub 5-1.3:1.0: hub_ext_port_status failed (err = -71)
    [31459.305216] usb 5-1.3-port3: cannot disable (err = -71)
    [31459.305719] hub 5-1.3:1.0: hub_ext_port_status failed (err = -71)
    [31459.306466] usb 5-1.3-port4: cannot disable (err = -71)
    [31459.331209] hub 5-1.3:1.0: hub_ext_port_status failed (err = -71)
    [31459.331579] usb 5-1.3-port2: cannot disable (err = -71)
    [31459.331582] PM: dpm_run_callback(): usb_dev_resume+0x0/0x20 returns -71
    [31459.331590] usb 5-1.3.2: PM: failed to resume async: error -71
    [31459.479397] OOM killer enabled.
    [31459.479398] Restarting tasks ...
    [31459.479962] hub 5-1:1.0: hub_ext_port_status failed (err = -71)
    [31459.481086] hub 5-1:1.0: hub_ext_port_status failed (err = -71)
    [31459.481695] done.
    [31459.481786] PM: suspend exit
    [31459.482006] usblp 1-1:1.0: usblp5: USB Bidirectional printer dev 2 if 0 alt 0 proto 2 vid 0x413C pid 0x5404
    [31459.482084] hub 5-1:1.0: hub_ext_port_status failed (err = -71)
    [31459.487091] hub 5-1.3:1.0: hub_ext_port_status failed (err = -71)
    [31459.487831] hub 5-1.3:1.0: hub_ext_port_status failed (err = -71)
    [31459.488580] hub 5-1.3:1.0: hub_ext_port_status failed (err = -71)
    [31459.489330] hub 5-1.3:1.0: hub_ext_port_status failed (err = -71)
    [31469.716724] usb 5-1.1: USB disconnect, device number 16
    [31469.716871] usblp4: removed
    [31469.717116] usb 5-1.3: USB disconnect, device number 17
    [31469.717119] usb 5-1.3.2: USB disconnect, device number 19
    [31472.258865] ata2.00: qc timeout (cmd 0xec)
    [31472.258880] ata2.00: failed to IDENTIFY (I/O error, err_mask=0x4)
    [31472.258884] ata2.00: revalidation failed (errno=-5)
    [31472.734874] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
    [31472.847558] ata2.00: configured for UDMA/133
    [31472.939209] usb 5-1.3.3: USB disconnect, device number 20
    [31473.684858] usb 5-1.3.4: USB disconnect, device number 21
    [31473.812753] usb 5-1.4: USB disconnect, device number 18
    [31473.972321] usb 5-1: reset high-speed USB device number 15 using xhci_hcd
    [31474.446871] usb 5-1.1: new full-speed USB device number 22 using xhci_hcd
    [31474.581261] usb 5-1.1: New USB device found, idVendor=0922, idProduct=0020, bcdDevice= 1.12
    [31474.581267] usb 5-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [31474.581270] usb 5-1.1: Product: DYMO LabelWriter 450
    [31474.581272] usb 5-1.1: Manufacturer: DYMO
    [31474.581274] usb 5-1.1: SerialNumber: 17081415344623
    [31474.586303] usblp 5-1.1:1.0: usblp4: USB Bidirectional printer dev 22 if 0 alt 0 proto 2 vid 0x0922 pid 0x0020
    [31474.678916] usb 5-1.3: new high-speed USB device number 23 using xhci_hcd
    [more happy devices follow]
    The only USB-related change I've made was to finally get around to connecting that multi-card-reader in the new-to-me DVD drive. Guess I should unplug that and see what happens?
  13. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    Check which USB port you have your hub plugged into on the m/b. On my rig, if I have my KVM USB cable in the wrong port, I have to press the power button to wake from sleep.
    I think it is something to do with having power or signal available when in sleep or suspend mode.
  14. The_Crapman
    5 Dec 2011
    I'm loving thermalright's comeback. Not just someone rehashing a brand name and using it to make a quick buck slapping it on something completely unrelated, but doing what thermalright was known for; making some of the best air coolers money can buy.
    I also have occasional issues with usb bugging out on waking from sleep. Happens (seemingly) randomly, not entirely sure why.
  15. sandys
    sandys Multimodder
    26 Mar 2006
    Not something I have experienced as I don't use sleep on desktop, no real need but my AMD based mobiles devices seem fine but they are zen4/zen5 so different chipsets I'd guess.
    check your board see what ports come from CPU, what comes from promontory chipset and what might be third party asmedia etc. and perhaps do a switch around and see if it goes away. There are typically usb 2 and various gens of usb3 so another variable to try.
  16. Gareth Halfacree
    4 Dec 2007
    Okay, found the curve optimiser. It's not under PBO in "AiTweaker", no, that's too easy. There's a different overclocking menu, hidden away in Advanced, then AMD Overclocking, then "Agree" to the scary warning, then PBO, then Curve Optimiser. Oh, and when you've made changes and go to save 'em? It tells you that you haven't made any changes... but it does save them. Oh, Asus.
    Anyway, tried all-core -20: insta-crash.
    Tried all-core -15: booted, but fell over after a few seconds.
    Now on -12, and it hasn't crashed... yet. Going to run the benchmarks again, see if it's made any difference and/or crashes on me.
    Fingers crossed!
    EDIT: Crashed!
    -10?
    EDIT EDIT: Nope!
    -8?
    EDIT EDIT EDIT:
    Hasn't crashed yet, but I'm waiting for tracker-extract to stop chewing up a CPU core in order to test it properly.
  17. yuusou
    yuusou Multimodder
    5 Nov 2006
    You sure you picked "negative?" I mean I've heard of people that were really unlucky with their CPU and curve optimizer, but crashing at -10 isn't the norm.
    MrsYuu has a 7950X and that does -25 all day long, I didn't even bother trying higher (lower). Mine does -20, was very unhappy with -25.
  18. Gareth Halfacree
    4 Dec 2007
    I am 110% sure I picked "negative," aye. Unless Asus has the options the wrong way round, which would not surprise me.
    It's stable at -8 (so far), but the real-world gains are... minimal. It's still spending most of its time at 4.4GHz all-core, with the occasional pop up to 4.5GHz but still dipping down to 4.3GHz (and at one point 4.2GHz).
    ImageMagick processing run took 4m12s at my old settings, 4m3s at the current ones. It's a gain, but... yeah, not much of a one.
  19. Gareth Halfacree
    4 Dec 2007
    Nope, crashed after nine minutes. D'you know what? I'mma go ahead and set all that back to "auto."
    EDIT:
    And for the avoidance of doubt:
    yuusou likes this.
  20. yuusou
    yuusou Multimodder
    5 Nov 2006
    T'is a shame. Either way, you'll enjoy a massive boost over the 2700X. Both in terms of performance and efficiency.
