Cooling Cooling Hard Disks
Discussion in 'Hardware' started by Cyprio, 26 Nov 2007.
  1. Cyprio
    Cyprio G5 Supermodder
    2 May 2006
    Now i would normally be the kinda person who replies to threads about cooling HDDs with "Not necessary". However, in my current build the only place for 2 Raptors (that will be Raid 0) is infront of the PA rad and hence will have warmish air flowing over them. The case itself has little airflow and so i am worried about them overheating a tad.
    I have looked into watercooling them but the blocks are large and expensive... but i had another idea i wanted to pass by people here.
    What about attaching an old waterblock to a copper plate and screwing the HDDs to this - would it work?
    Alternatively is anyone here able to make me a very simple waterblock that would consist of two parallel 10mm holes drilled into a copper block (that would be wedged between the two drives), and all 4 ends tapped for G1/4" compression fittings?
    Or is this just me being silly and HDD cooling is "Not necessary" :D
  2. Rocket733
    Rocket733 Austerity - It's the only way
    27 Dec 2003
    What about making the ghetto blocks out of copper pipe soldered to a plate that is attached to the drives? I imagine it shouldn't be too hard to make, cost much and would be quite effective as harddrives don't put out that much heat. If that's not really feasilbe I'd got without unless you run into stability issues.
  3. desertstalker
    desertstalker What's a Dremel?
    7 Feb 2004
    if they have the exhaust air from the rad flowing over them then I suspect they would be fine. HDD just need some airflow to prevent heat build up.
  4. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    how warm is the air coming out of the rad?
  5. Skylined
    Skylined Minimodder
    3 May 2003
    Maybe something like this?
    I know that it isn't WC, but I don't think that you need it to cool down a HDD.
  6. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    I have something similar, except that its just the finned bits of aluminium screwed on with some cheap thermal paste between them and i extended the bar out into the air flow up the case. Seems to work quite well.
  7. IAmATeaf
    IAmATeaf Minimodder
    9 Jun 2006
    Jeez skylinedis that a 38mm delta on the back of that case? Whoosh for the win :0
  8. Mister_Tad
    27 Dec 2002
    Give it a go with just cooling them with the airflow from the rad, keep an eye on the temps when you first put them in - unless theyre running over 50C, don't worry about the temps.
  9. Jipa
    5 Feb 2004
    Even hot airflow makes a hellofadifference when compared to situation with no airflow at all. Give it a shot is my advice as well.
  10. Cyprio
    2 May 2006
    Thanks guys. Will give it a shot without any extra cooling first.
  11. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    Just for reference, I have a Raptor 150 and a WD Caviar both inside Scythe Quiet Drive enclosures, and they are right next to my PA 120.1 (with about 70 watts worth of heat going through it). I have the air flowing through the rad and across the drives. They run about 37-40 C at the most during hardcore gaming.
  12. Skylined
    Skylined Minimodder
    3 May 2003
    Not a Delta, but they're both (the one at the front and the one at the back) 120x38 fans, but they run at a very low voltage, so I can have the air flowing without noise. :)
