Cooling Cooling i7 920
Discussion in 'Hardware' started by Dmc, 14 Nov 2010.
  1. Dmc
    Dmc Member
    13 Jul 2004
    Which is better the Corsair H50 or the Coollt ECO ALC, both about the same price £58 dont really want to spend any more than this. :D
  2. Big Elf
    23 Apr 2009
  3. bulldogjeff
    2 Mar 2010
    I'd say go for the H70 if you want to go this route. Having used the coolit and the H50 I would say go with the H50, they are pretty much the same on standard speeds but the H50 does much better when overclocked, especially when set up in push/pull config.
  4. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Do you move your system often? If yes, go for the Corsair H50/H70 as this places 90% of the weight of the cooler on the case, so no paranoia of killed motherboards. If no, go for the TT Frio, as it's a very good cooler at a very good price.
    Either way, stay away from CoolIT products. If you google it, many of them get broken barbs and leak...
  5. bulldogjeff
    2 Mar 2010
    The new cool It gears way better that the original stuff that the Bit-tec lads destroyed.
  6. Bloody_Pete
    11 Aug 2008
    At last...
  7. rob the bank
    rob the bank New Member
    13 Mar 2010
    Or a Thermaltake Frio better and cheaper then the cheap WC.
  8. heir flick
    heir flick Active Member
    2 Feb 2007
    Im useing the h50 with push pull fans and no complaints, does tbe job fine
  9. spicycoky
    spicycoky How is better than Why
    21 Nov 2010
    Just get the H-70, more bigger radiator and also included with two fans!
